Author Topic: What causes bent rods?  (Read 1909 times)
Omega man 2
« on: 29 January 2009, 17:40:55 »
As above. I just don't want it to happen again after rebuilding my engine :-/
Richie London
  • heathrow
Re: What causes bent rods?
« Reply #1 on: 29 January 2009, 17:44:54 »
my rod usually bends after too much alcohol  ::) ::) ;)
LaserLance
  • medway towns
  • Red or Black please!!!!!!!
« Reply #2 on: 29 January 2009, 18:05:13 »
I like the bend in me "rod " when I got a 20lb carp on the end of me line ::) ::) ::) ;D
« Last Edit: 29 January 2009, 18:05:40 by LaserLance »
Ian_D
  • York
« Reply #3 on: 29 January 2009, 19:45:46 »
going through deep water and sucking it up the air intake!
Then as the piston rises, it cant compress the water (Hydrolocks), so something has to give... and the rod bends!
[size=12]
hotel21
  • The Kingdom of Fife
« Reply #4 on: 29 January 2009, 19:47:53 »
Timing, mainly.
And hydraulicking, if it sucks up water...
« Reply #5 on: 29 January 2009, 19:51:41 »
Seized big ends (oil supply)
Seized little ends (oil again)
Hydraulicking
Seized piston
« Last Edit: 29 January 2009, 19:51:51 by Mark »
Omega man 2
« Reply #6 on: 29 January 2009, 20:30:53 »
Timing, mainly.
Could it be caused by igniting fuel prematurely while the piston is still rising?
« Reply #7 on: 29 January 2009, 20:39:20 »
Timing, mainly.
Pre-ignition normaly melts pistons....the rods are normaly ok
Omega man 2
« Reply #8 on: 29 January 2009, 20:41:16 »
Timing, mainly.
Ah thats ok then ;D
hotel21
« Reply #9 on: 29 January 2009, 20:42:37 »
Timing, mainly.
I was thinking on a more physical interaction type thing where the timing belt slipped a tooth or three and valves and pistons were shoving tongues down each others throats.....    :D
« Reply #10 on: 29 January 2009, 20:56:12 »
Big heavy fish ::)
Taxi
« Last Edit: 29 January 2009, 20:56:39 by Elite_Pete »
Omega man 2
« Reply #11 on: 29 January 2009, 20:58:08 »
Big heavy fish ::)
Taxi
Well it happened in the simpsons so its possible ;D :D
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
« Reply #12 on: 30 January 2009, 10:30:28 »
Mine Didn't! :)
Ian_D
  • York
« Reply #13 on: 02 February 2009, 00:30:18 »
Mine Didn't! :)
Water wasn't deep enough then!  :P ;D
[size=12]
