Author Topic: Passed my MOT  (Read 4541 times)
GaryB
  • Stanmore
Re: Passed my MOT
« Reply #15 on: 16 January 2007, 21:04:57 »
"LAMBDA MIN = MIN = 0.97, MAX = 1.03, ACTUAL = 1.01
Looking at the min and max for the Lambda, suppose its not too bad.
What is the units of the lambda test / what is it??"
Lambda is a ratio, which shows how rich or lean the engine is running - ideal is one (the stochiometric ratio of fuel to air - 14.6ish to one iirc, but we could look it up....), so yours is ok, (and very nearly spot on).
« Last Edit: 16 January 2007, 21:07:30 by GaryB »
miked
  • North Yorkshire
Re: Passed my MOT
« Reply #16 on: 17 January 2007, 09:55:28 »
Might just leave it alone then!
Thanks for the info.
nixoro
  • Hitchin, Herts
Re: Passed my MOT
« Reply #17 on: 17 January 2007, 10:19:55 »
Miked
I have had this link for some time it may prove useful, I believe the creator is a member on here.
http://uk.pg.photos.yahoo.com/ph/agw625/album?.dir=mail&.src=ph&store=&prodid=&.done=http%3a//uk.pg.photos.yahoo.com/ph/agw625/my_photos
It shows the process of a headgasket change on a 2.0 picture 32 shows the manifold removed with the cat still in place.
Should give you some Ideas of whats involved.
Good Luck if you do it.
Hope this helps  :y
« Last Edit: 17 January 2007, 10:22:57 by nixoro »
