Author Topic: Any help with quote from garage for this work pls  (Read 2310 times)
tampon
  • West London
Re: Any help with quote from garage for this work pls
« Reply #15 on: 11 February 2009, 17:52:33 »
why do you need a new cat?  did it fail emissions?
Yes, they said both of these would sort it out.
Can you post the results of the emission test? Wouldn't trust the diagnosis of kwik-fit ::) ::)
The test said this
test one
engine speed 2500-3000 pass
co:       <=0.300 %    I got    0.433%   fail
Hc:       <=200ppm    I got    78pp,      pass
Lambda: 0.970-1.030 I got    1.033      fail
2nd
Co:        0.411% fail
Lambda: 1.035    fail
Also failed centre seat belt ( missing ), I think it is just under the seat, if not could I just unbolt the centre restraint completly and it then pass ? ie if it is nto there then they can;t test it ?
Nearside hub bearing assembly ( doesn't say what it failed on just that it did.)
Parking brake below requirement
Rear brake binding
So what the great minds here think.
Got a friend who works for Volvo, he is going to sort the stuff out with the brakes but he said that might be expensive and said it will be a pain in the arse ( thats what friends are for ) and get one of his pals to look at the emissions stuff. Any way I look at it he is going to only charge me a few beers for the work, any ideas on parts for those parts with the brake/hub bearings
I think maybe a new Lambda sensor ( would that change the co rating as well ? ) based on no experience what so ever, and any tips from you guys really.
Thanks to all the guys who shared info as to where to get cats, sensors etc really been useful.
willyboy
  • Leeds. West Yorks
  • Can Do !!
« Reply #16 on: 11 February 2009, 18:21:06 »
Didnt think they tested emissions on mine 99 2.0 cd as it was too old dunno about 2000 reg I maybe mistaken but pretty sure  but have many grey cells  so could well be wrong again :-[
« Reply #17 on: 11 February 2009, 20:19:46 »
Hmmm... Is there a leak in the exhaust anywhere?
Any leak in the exhaust can be known to cause issues with readings. Secondly, did you give it an Italian Tune Up on the way to the MOT?
Personally, if I were uncomfortable with checking it over myself, I'd find a small independent garage for a second opinion (without telling them about the KF MOT!)
Hub bearing assembly, I assume, means excessively worn wheel bearing.
Seatbelt - Yes, but not advised... It's bound to be there
As for the brakes... Bet it's not binding at all... Probably diff drag ::) ::) :-X
Handbrake - Probably just needs adjusting up :y :y
Hope some of that helps :y :y
tampon
  • West London
« Reply #18 on: 12 February 2009, 12:41:56 »
Awesome thankyou for your advise, I will pass that on to my buddy.
Cheers
« Reply #19 on: 12 February 2009, 12:51:07 »
Does not sudgest the Lambda is at fault.....needs more diag
Is the car getting upto temp?
Running ok?
Genuine Cat or cheap aftermarket shite?
Any fault codes
tampon
  • West London
« Reply #20 on: 12 February 2009, 16:48:07 »
Running ok?
Any fault codes
Gets up tp temp fine no problems
Runs absolutely fine
One thing is when it is started the exhaust has always sounded "throaty" for a minute and then when starts to get warm it is like something shuts and it is nice and quiet.
The Guy at kwikfit said that someone had bodged a weird cat on there, said it was square and almost looked like it was off a motorbike. So i would say aftermarket bodged on shite.
