Author Topic: Coil per plug help  (Read 2309 times)
Coil per plug help
« on: 18 January 2007, 10:17:52 »
OK, not quite.
Rover, is has one seperate coil per 2 cylinders, but them coils plug in directly on top of the plug in a similar fashion to coil per plug Vauxhalls.
One of mine had no real connector to plug, just like a ballpoint pen type spring.  So I bought another, and its the same  :-?
The other coil on the engine has a proper connector similar to that found on a plug lead.
Is this normal?
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
Re: Coil per plug help
« Reply #1 on: 18 January 2007, 10:24:41 »
Not worked on a 25 but not familiar with this on the 200`s ( but its been a while)
what particular one in sprung?
Part numbers the same on old and new - if so sounds like the norm  :-/
« Reply #2 on: 18 January 2007, 10:31:22 »
I thought the 200s/400s had a different setup, with the coil/distributor to one side of engine, not with 2 coils on top 2 of the plugs (and 2 short (6")) leads to other plugs?
Markie
« Reply #3 on: 18 January 2007, 10:33:50 »
some are the same and engines interchangable......coil/ dizzy pack on right hand side of block ?
« Reply #4 on: 18 January 2007, 10:36:56 »
No dizzy.  2 coils, sit directly on plugs 1 and 3, with short HT leads going to plugs 2 and 4 from these...
« Reply #5 on: 18 January 2007, 17:30:58 »
The only K series ones I've worked on had dizzy/leads....
Hrm.. you having probs with this ignition pack?
theolodian
  • I need a new avatar.
« Reply #6 on: 18 January 2007, 17:54:26 »
Don't know about Rovers, but loose springs are a common type of coil-on-plug setup.  Probably switched over to that style to save money.  Now those would supercede the old type and are what you get new.  Make sure that the little screw-on cap is on the spark plug (not bare threads), and you'll be fine.
« Reply #7 on: 18 January 2007, 18:50:53 »
Thanks - that a reassurance :y
Its just the other coil has a 'proper' connector in its plug connector...
Page created in 0.023 seconds with 20 queries.
