i may have a problem....
Started by tunnie, 21 January 2007, 22:47:49
STMO123
QuoteJaime and I were saying the other day.. it takes a scare to make someone a better driver...
I'd consider myself very safe...but largely because I've had some close calls and learned from it.
agreed...
high speed blowouts can really concentrate the mind...
errrr....make sure you've got decent tyres on it ::)
QuoteJaime - The brakes have been getting better strangely, i think a film might have developed on the pads since its been stood for so long, it brakes a LOT better now than when i first picked it up. Done sod all to the brakes too.
My point about the brakes is that, even if in perfect condition, is they are what was fitted to early 2.0l (not the larger ones fitted to 2.2)...
if your talking about the senator brakes they are exactly the smae as the 3lit Omega mate!! where do you think the Omega brakes came from??
Omegatoy
Sennys are 286mm aren't they - the same as early 2.0l.  v6 had 296mm
I'll get the rims off and have a check... be usefull if they are the same.
