Pages: 1 [2] 3  All   Go Down
Author Topic: Car Mechanics Article on Battery Chargers  (Read 9580 times)
Markjay
  • London
Re: Car Mechanics Article on Battery Chargers
« Reply #15 on: 22 January 2007, 12:08:14 »
I don't entirely understand why would you need a charger in the first place... unless the car is in storage for a long period of time, any need for charging suggests that there is a problem:
1. Something is drawing too much current with the ignition switched off
2. The battery is in need of replacing
3. The alternator does not charge properly due to a fault (damaged coil, faulty voltage regulator, etc)
4. The alternator does not charge properly due to auxilary belt problems (failed tensioner, slipage due to oil leak or glazing, etc)
etc, etc...
If this is the case, why not simply find and cure the source of the problem? If the battery needs replacing, for £30+ and a five minutes job, just get it done... it will be good for another 5 years or so. Why trickle charge a faulty battery?
As for storage, I found that I have no problems at all when the car is parked for up to 2-3 weeks (when on holiday etc). On my other car, I simply disconnect the battery - it's a very basic car with no alarm or radio code etc so the battery can just be connected and disconnected. In fact I even have a proper battery cut-off switch installed between the negative terminal and the car body, so no need for a spanner. You will be surprised how long can a car battery keep it's charge when it is disconnected - months is no problem.
And, in the unlikely event that the battery does go flat (e.g. when TB updated the firmware... lol), a quick jump-start and then a short blast on the motorway seem to cure the problem.
So, again, why do you guys need battery chargers in the first place?  :o
Shortish journeys, esp in winter....
In my experience - with a good battery, properly charging alternator, and no current-drawing faulty devices, you will not need a battery charger even with short winter journeys... I suspect that most cases where a trickle charger is needed it is actually covering-up a problem - usually an ageing battery.
Alas, no more Omegas....
« Reply #16 on: 22 January 2007, 12:09:55 »
etc, etc...
The old addage that you need a 20min run to put back in a 5s start?  Couple that with HRW on, possibly seat heaters, wipers, lights etc etc...
Markjay
  • London
« Reply #17 on: 22 January 2007, 12:13:24 »
etc, etc...
OK, I suppsoe that if you take into account LB's sound system (or so I heard) then yes, you could flatten the battery in one short journey...  ;D
« Reply #18 on: 22 January 2007, 12:21:44 »
etc, etc...
A weeks worth of short winter journeys will make a significant dent in the battery capacity...
x25xe
  • Hayes, Middlesex
  • Avater removed due to size
« Reply #19 on: 22 January 2007, 13:18:42 »
etc, etc...
Fully agree with your list of why the battery is going flat.  However, I am looking for a charger as the car is left standing for anything up to 2 months.  With the alarm and immobiliser on all the time, the battery is somewhat drained.  I was hoping to be able to connect a trickle charger to avoid this.  According to the web site of the manufacturer, this is safe to do, but there are doubts in the back of my mind to be honest.
http://www.ctek.com/EN/MXS3600/features_benefits.asp
Apparently, there is virtually zero ripple and the output is finely controlled.  It is based on a switch mode PSU rather than a transformer and bridge rectifier etc.
Markjay
  • London
« Reply #20 on: 22 January 2007, 13:32:36 »
This is what I have on the wife's MPV:
http://www.demontweeks.co.uk/products/ProductDetail.asp?cls=MSPORT&pcode=LMA789C
Admitadly, it will also cut-off any alarm you have (the MPV has none), you will need to re-code the radio (the MPV does not have a code on the radio), and the engine and gear ECU will forget everything (the MPV does not learn anything in the first place). So maybe not such a bright idea to use on the 'meega  ;D
« Reply #21 on: 22 January 2007, 13:54:41 »
The PSU type won't make huge amounts of difference, though admittedly the smps will be at much higher frequency so arguably easier to smooth.  But a well designed linear psu will be every bit as good (though probably heavier!)
Taxi_Driver
« Reply #22 on: 22 January 2007, 18:53:27 »
I only have a battery charger for just in case.....i have taxi kit fitted and it does drain the battery a bit....sometimes i forget to switch it off in the evening so its on all night...its powering a colour lcd screen....and a tx that i think transmits at about 4w.....and is always tx'ing......ok not much power but if the battery was low....and i do about 20-30 starts a day also hammering the battery.....sometimes turn off during these gloomy days and forget to turn off headlights....plus i use the auto button quite a bit at the mo when turned off.....also draining the battery.....so as i said MJ its only for just in case....as i dont like jump starting if a flat battery.....once fubared a veccy ecu by doing that!
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« Reply #23 on: 22 January 2007, 19:14:46 »
etc, etc...
I seem to remember a certain somebody (who shall be nameless, of course) sat with his headlights on when he was speaking on his mobile.....and ended up with a flat battery.... ::)
I like red cars
Taxi_Driver
« Reply #24 on: 22 January 2007, 19:54:06 »
etc, etc...
Now you mention that AA......so do I  ::)
Markjay
  • London
« Reply #25 on: 22 January 2007, 21:05:26 »
etc, etc...
« Reply #26 on: 22 January 2007, 21:53:46 »
must be honest, I don't like the idea of charging the battery while it's still on the car....
Am agreeing here
Markjay
  • London
« Reply #27 on: 22 January 2007, 22:51:24 »
etc, etc...
AA and TD, I’ll have you know that
1. This was an isolated incident
2. It happened next to my office, so even if I had a battery charger (at home) it would not have helped
3. I called Green Flag, but managed to get the car going before they arrived
4. Even if it did happen at home, I wouldn’t have been able to use a battery charger because I park in the street and don’t have a garage!  >:(
So there….
« Last Edit: 22 January 2007, 22:53:07 by markjay »
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #28 on: 23 January 2007, 08:45:21 »
etc, etc...
So there….
Excuses, excuses, excuses....
I like red cars
Taxi_Driver
« Reply #29 on: 23 January 2007, 12:54:24 »
etc, etc...
So there….
Im sure tho MJ, if you did have one you would carry it in the boot with everything else.....and im sure you have the correct tools to remove the battery and carry it inside to charge ::)  ;)
Pages: 1 [2] 3  All   Go Up
Page created in 0.028 seconds with 20 queries.
