Pages: 1 2 [3]  All   Go Down
Author Topic: Grotty tyre choice  (Read 3097 times)
Re: Grotty tyre choice
« Reply #30 on: 06 March 2009, 23:13:03 »
                          diameters                    Circumferences
205*55*15           >> 647.5 mm                2034.2 mmm
225*55*16           >> 653.9 mm                2054.3 mm
                                  +6.4 mm                  20.1 mm
    at 80 km/h
 80,0000 meters / 3600 sec  = 22.222 m/sec =22222 mm/sec
205*55*15  >>>  10.924 turns /sec
225*55*16   >>> 10.817 turns / sec   :-?
which is quite different.. :-/
5/10 Must try harder :)
The 15" standard tyre is 205 65 15, look up the circumference for that and it should be very close to that of the 225 55 16
That makes far more sense ...  I can't see Vx fitting a spare that is so different to the "normal" tyre.
I "believe" one of the reasons for the difference in size is not just the "hole" it fits into .. but the fact that it was designed that way as the cost of alloy wheels in those days was quite high .. so a steel wheel with a different profile tyre was much cheaper than an alloy spare + normal tyre .. and the storgae area was designed around that. The spare is then "thinner" so gives more boot space ...
« Reply #31 on: 06 March 2009, 23:15:48 »
                                  +6.4 mm                  20.1 mm
    at 80 km/h
my  mistake all my calculations are based on 205 65 15  but I write it wrong ;)
and definitely if you use that spare on the front the car wont go straight ..
« Last Edit: 06 March 2009, 23:16:39 by cem_devecioglu »
« Reply #32 on: 06 March 2009, 23:16:17 »
                                  +6.4 mm                  20.1 mm
    at 80 km/h
I must re check the spare in our Mig, I am sure it is an unused full size alloy, on a 1998 GLS estate ::) ::). Been a while since I looked :-[
« Reply #33 on: 06 March 2009, 23:18:13 »
                                  +6.4 mm                  20.1 mm
    at 80 km/h
205*65*15           >> 647.5 mm                2034.2 mmm
                                  +6.4 mm                  20.1 mm
    at 80 km/h
205*65*15  >>>  10.924 turns /sec
corrected!
« Last Edit: 06 March 2009, 23:22:10 by cem_devecioglu »
« Reply #34 on: 06 March 2009, 23:20:03 »
Mine is certainly a "steely"  .. I'll check the size tomorrow  ... :(
In the meantime  ... this site might save some overheating calculators ...
http://www.tyresave.co.uk/tyresize.html
« Reply #35 on: 06 March 2009, 23:24:56 »
 ;D :y
I used that link
http://www.miata.net/garage/tirecalc.html
Pages: 1 2 [3]  All   Go Up
Page created in 0.028 seconds with 16 queries.
