Author Topic: Removing Oil from Plugwells  (Read 2669 times)
Re: Removing Oil from Plugwells
« Reply #15 on: 10 March 2009, 21:47:10 »
I Used a thin plastic pipette thingy to suck the oil out of the wells
I used to do that kind of thing, but I have gone off the taste of oil or petrol if I can avoid it! :D :D ;)
Use in conjunction with a syringe :y
With a syringe Pete! :o :o :o
Call yourself a mechanic! ::) ::) ;D ;D ;D ;)
Saves you spitting or swallowing :D ;)
 ;D ;D ;D ;D ;D ;D ;D ;)
« Last Edit: 10 March 2009, 21:47:29 by Lizzie_Zoom »
Proz
  • Largoward , Fife , Scotland
    • Omega-less now :-/
« Reply #16 on: 10 March 2009, 21:47:55 »
Saves you spitting or swallowing    oooo errr  :D
Proz
« Reply #17 on: 10 March 2009, 22:04:23 »
Just noticed i've been knighted  ..... :D
« Reply #18 on: 10 March 2009, 22:51:17 »
Congratulations..... :y :y :y
willyboy
  • Leeds. West Yorks
  • Can Do !!
« Reply #19 on: 11 March 2009, 00:13:52 »
Cheap plastic syringe of egay does the job  :y
« Reply #20 on: 11 March 2009, 00:16:48 »
Another 'flirter' getting worried about this forum :o :o :o
http://egay.co.uk/
« Last Edit: 11 March 2009, 00:19:44 by floodm »
Welung666
« Reply #21 on: 11 March 2009, 06:09:01 »
I use a 60ml syringe with about a foot of clear tube (from my old fish tank pump) on the end, works a treat :y
« Reply #22 on: 11 March 2009, 10:02:13 »
Yep, I use the same setup to drain the brake fluid reservoir before re-filling with fresh fluid when doing a brake fluid change.
Its worth also removing the plugs after soaking the oil up and cleaning the spark plug bores with a clean cloth. Any small amount of oil in the wells wont hurt.
« Reply #23 on: 11 March 2009, 15:48:02 »
Well done Sir Proz!! :D :D ;)
