Pages: 1 [2] 3  All   Go Down
Author Topic: ann's honda civic query?  (Read 2686 times)
nick v6
  • walsall / west midlands
Re: ann's honda civic query?
« Reply #15 on: 10 March 2009, 15:51:16 »
ive had a sdimilar experiance with SWMBO's Old Rover they riip you off good & propper btw i emailed my friend mark so am awaiting his response he should get back to me by COP 8pm
nice 1 :y
it got to be some sort of air/fuel flow sensor
or something to do with the auto choke
when its warm the revs go really low close to cutting out
but it don't do it all the time
when it does do it it can be a pain to start
« Reply #16 on: 10 March 2009, 16:10:22 »
Surley its injection at that age!
nick v6
« Reply #17 on: 10 March 2009, 16:11:46 »
yes its injection
the air box sits at the top just at the back of the engine
ill take some pics of the engine and post them on the site
« Reply #18 on: 10 March 2009, 16:16:14 »
Well its probably a D8 or D9 era engine.
So 16V EFi without VTEC.....and certainly no choke!
nick v6
« Reply #19 on: 10 March 2009, 16:17:28 »
where do i find that
its only 8 valve
« Reply #20 on: 10 March 2009, 16:20:35 »
What spec LS auto?
nick v6
« Reply #21 on: 10 March 2009, 16:22:32 »
What spec LS auto?
1.6i LS coupe
nick v6
« Reply #22 on: 10 March 2009, 16:27:22 »
this is the airfilter on top of engine at the back
this is the air filter inside
there are the injectors
« Reply #23 on: 10 March 2009, 16:30:49 »
It could be one of about 6 different engines!
Al very revvy with little low down torque which is acceptable in something as light as a Civic (about 1200Kg). Not to hot on the safety as a result though.
Basically its a Hondaised Rover 400
nick v6
« Reply #24 on: 10 March 2009, 16:32:20 »
is there a way of finding out what engine it is
Martin_1962
« Reply #25 on: 10 March 2009, 20:17:55 »
That isn't light that is the same weight as my Carlton was :o
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #26 on: 10 March 2009, 21:47:04 »
Hiya,
Sounds like the idle control valve to me. He should have a service connector in the passenger foot well. Stick a paperclip in it and it'll flash the engine light. It'll be like say, 3 long flashes and 3 short flashes is code 33. Google honda ecu codes and it'll tell you whats wrong. The idle control valve has a code of its own so you'll know if its that. If it is that, a bit of carb cleaner will possibly fix it. Otherwise, you'll have to find another civic coupe with one. One off another honda civic wont go, unless its a d16y7 engine too, which is unlikely as I think only the civic coupe got the d16y7.
btw he says you have the D16Y7 so its a D Series lump
thats what my mate has said seems like the miggys paper trick works
« Last Edit: 10 March 2009, 21:48:45 by tmx »
nick v6
« Reply #27 on: 15 March 2009, 16:00:31 »
i'm starting to think the exhaust is blocked
it don't sound very good at the back of the car when its reved
might try changing the exhaust first and see what happens and take it from there
it needs a new exhaust so can't go wrong really
nick v6
« Reply #28 on: 16 March 2009, 19:15:16 »
ive taken the idle control vale off the civic
and what a wierd design
it has a water feed that runs in to and out of the valve
and ive had a look and it is black as anything
and where it bolts on to the carb all inside there is gacked up with crap
so it looks like the problem is there
i will be getting some carb clean tomorrow and giving it a good cleaning and then try again and see how that gets on
but for how gacked up it was i'd say when its cleaned out it will run perfect :y
i hope :-/
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #29 on: 16 March 2009, 19:22:45 »
my mate was right then he will be pleased to know that! :y
Japanese Cars are complex but work reliably
Pages: 1 [2] 3  All   Go Up
