Pages: 1 2 [3]  All   Go Down
Author Topic: Bike Folk - Scottoilers  (Read 3840 times)
Omegatoy
  • UK
Re: Bike Folk - Scottoilers
« Reply #30 on: 17 March 2009, 20:58:17 »
had a couple of bikes with scottoilers and they were ok for chainlife, but the easiest way for us was to extend the breather pipe from the rocker covers to exit just on top of the chain, kept it well lubed!!! :y
« Last Edit: 17 March 2009, 20:58:33 by Omegatoy »
Martin_1962
« Reply #31 on: 17 March 2009, 21:23:30 »
I used ot have a big can of grease you melted the chain into - that worked - my dad had bikes too - that helped
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
« Reply #32 on: 17 March 2009, 21:32:40 »
Hmm...that sounds a good idea, but not sure of the effects the waste products would have on an o-ring chain.
My engine is vented into a catch can and breather filter, which I empty once a month and there's a fair amount of mayonaisey type cr*p that comes out.
The engine is spot on and I've never needed to top up the oil between changes(:o w.t.f...it's a Harley !).
There must be some bi-products in the breather gases to cause that much gunge.
Omegatoy
  • UK
« Reply #33 on: 17 March 2009, 21:41:43 »
wouldnt have thought so its just that your catch tank is cold and it causes the condensation to mix with the oil causing mayo, and for the record know of 2 harleys that have done this mod!! :y
r1
  • nottingham
« Reply #34 on: 17 March 2009, 23:05:26 »
as its only a 125 get a full chain guard,cost about 30 quid you still have to lube it but fitted one to my sons honda 125 bike sold 3 years later with nearly 25000 miles and plenty of chain life left
r1
  • nottingham
« Reply #35 on: 17 March 2009, 23:07:06 »
thought harleys were belt drive
PaulW
  • Somewhere near Manchester
  • Come on you fiend!
    • Some crappy Insignia
« Reply #36 on: 17 March 2009, 23:19:04 »
Already has a full chain guard fitted
Humbugs...
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
« Reply #37 on: 17 March 2009, 23:23:56 »
Most recent are belt driven but the older ones are chain and some owners of newer H-D's convert to chain. I quite like the ease of the belt system.
They say chain is better for modded H-D's but I've had no problems with a 1200 conversion, N4 cams, modified heads and a Screamin' Eagle 8k ignition module.
« Reply #38 on: 18 March 2009, 11:17:03 »
Leather strap in the days of steam mate. ;D so olive oil for your scott oiler i guess?
Pages: 1 2 [3]  All   Go Up
