Author Topic: Someone put my mind at rest please!!  (Read 2094 times)
Big Rod
  • Fife, Scotland
« on: 27 January 2007, 19:55:37 »
In anticipation of work starting on my house on Monday, I thought that it was high time to sort the wheat from the chaf WRT the contents of my garage..............
I have to admit I hoard a lot of sh1t!!  ::)
Anyways, I was being brutal about what should stay and what should go. I slung a good working, (when it was removed.), A/C pump from a Senator. Shame, but I wasn't likely to use it.
So I jumps in SWMBO's Elite and there's a hideous rumbling noise from under the bonnet. So I switched the A/C off and the noise disappeared. So I figured A/C pump!!  :o
Someone please tell me that the pumps are different and I've not thrown away a useable part!!!! Please please please!!
(Oh and I'll probably be after a replacement pump in future if anyone's got a known good one kicking about!!)
« Last Edit: 27 January 2007, 19:56:45 by Big_Rod »
If I have to explain you won't understand!
STMO123
Re: Someone put my mind at rest please!!
« Reply #1 on: 27 January 2007, 19:58:15 »
The pumps are EXACTLY the same!
STMO123
« Reply #2 on: 27 January 2007, 19:59:27 »
Or maybe not ;D ;D
Omegatoy
  • UK
« Reply #3 on: 27 January 2007, 20:00:13 »
apart from the different seals used and the fact that the pipes enter and exit at different places and at different angles you mean????
Omegatoy
Big Rod
  • Fife, Scotland
« Reply #4 on: 27 January 2007, 20:00:58 »
The pumps are EXACTLY the same![/quoteYou have GOT to be sh1tting me!!!  :'( :'( :'( :'( :'( :'( :'(
Sh1t! f*ck!!! @rseholes!!!  AAAAAaaaaaaaararrrrrrrrgrgggggghhhhhhhhhh!!!!  >:( >:( >:( >:( >:(
Big Rod
  • Fife, Scotland
« Reply #5 on: 27 January 2007, 20:01:42 »
Or maybe not ;D ;D
Git!  :y
Big Rod
  • Fife, Scotland
« Reply #6 on: 27 January 2007, 20:02:19 »
Omegatoy
Thanks for putting my mind at rest G'!!  :y
Chopsdad
  • Bouncy Castle in Carlisle
  • Keep it clean!
« Reply #7 on: 27 January 2007, 20:32:59 »
Never ask a question you don't really want the answer to. ;D ;D
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
« Reply #8 on: 28 January 2007, 09:55:48 »
different Rod, dont worry  :y oh and sealed unit so cant be adapted or made to fit  ;D
Omegatoy
  • UK
« Reply #9 on: 28 January 2007, 17:45:49 »
Sorry dude but wrong!! you can fit complete Omega aircon system compressor and rad to a senator!! have seen it done and it all works fine!! however it cannot be done the other way round i.e senny into Omega!!
Omegatoy
Markie
« Reply #10 on: 28 January 2007, 18:20:14 »
Omegatoy
really  :o then i stand corected  :-X :y reason i thought was becuase i have seen it tried from Senny to omega.....and it didnt work, presumed the same in reverse...
« Last Edit: 28 January 2007, 18:21:11 by Markiec »
Omegatoy
  • UK
« Reply #11 on: 28 January 2007, 18:33:38 »
Omegatoy
Yeh but the guys has a distinct advantage over us he is a master tech in a vxhall stealership so has access to all the parts, its his senny that has Omega aircon on !!!
Omegatoy
