Author Topic: Breather system clean how to  (Read 2020 times)
AndersH
  • Poole
« on: 29 January 2007, 21:42:12 »
Is it just me or have the pictures disappeared from the breather system clean how to?
http://www.omegaowners.com/forum/YaBB.pl?num=1152598350
Wanted to do this but am thick and can't do it from the text alone   :-/
Chopsdad
  • Bouncy Castle in Carlisle
  • Keep it clean!
Re: Breather system clean how to
« Reply #1 on: 29 January 2007, 21:50:41 »
They've not gone - they were never there ;)
Check out the guide for 2.2 created by Auto Addict, who was kind enough to take snaps.  :y
Chopsdad
  • Keep it clean!
AndersH
  • Poole
« Reply #3 on: 29 January 2007, 21:54:37 »
Cheers,
Is it pretty much the same for a V6 then?
Chopsdad
  • Keep it clean!
« Reply #4 on: 29 January 2007, 21:58:57 »
Cheers,
Pretty much, just different shaped pipes and locations.  Good luck  :y
AndersH
  • Poole
« Reply #5 on: 29 January 2007, 22:04:39 »
That's what I'm worried about! if anything looks slightly different I'll chicken out!
bestseany
  • Flintshire, North Wales
« Reply #6 on: 30 January 2007, 09:21:27 »
I had trouble following the breather how2 mate. The lack of pictures made it very difficult.
The easy part is the black box on the plenum, just follow the two large breather pipes on the back of it (they're a y-piece going into one tube), this connects to the breather box. The breather box is at the back of the drivers-side head. You can see it in this picture with the large and small rubber pipe going into it.
Make sure you take off the small pipe and use a pin to clear the pin-hole in the pipe neck.
