Pages: 1 [2] 3 4 5 6   Go Down
Author Topic: Bushes for my wishbones  (Read 7161 times)
psychnurse
  • Leominster, Herefordshire
  • Whats in the fridge today? Beer and Sausages....UM
Re: Bushes for my wishbones
« Reply #15 on: 28 July 2008, 17:39:21 »
Polyurethane is much harder so is likely to make the ride a lot firmer.
I suspect it wont be suitable for the vertical rear bush as this requires quite a degree of flex
Gotcha!  :y :y :y
Well in that case  ::) ::) I am intereted too  :y
« Reply #16 on: 28 July 2008, 18:03:00 »
just ordered front pair wishbones £58 all in from the vaux centre.
http://www.vauxcentre.co.uk/index.php?product_id=485975&option=Prod_detail&image_id=190941
comes with 12 month warranty
sorry for thread hijack :-[
Is the nearside one predrilled for HID level sensor (2 holes)?
johnnycboy
  • Colchester
« Reply #17 on: 28 July 2008, 18:12:37 »
i wont know until they arrive tomorrow, i'l let you know then.  i would presume so. :-[
iggy21uk
  • Berkhamsted - Herts
  • Omega Spotter -  tats gone tanning
« Reply #18 on: 28 July 2008, 18:13:07 »
Me going to stick with the rubber goods!  ::)
Poly might make the ride to hard harsh ?
« Last Edit: 28 July 2008, 18:13:44 by iggy21uk »
[size=10]Opelscanner Can owner / Cam lock kit owner [/size] [/i][/b]
ians
  • Reading
« Reply #19 on: 28 July 2008, 22:04:14 »
There is an uprated Meyle bush used on the 5 series BMW's which will fit....
Any ideas of the part number please, the part numbers I have is
614 035 0016 &
614 035 0010
Just found this is this the one .5mm smaller o/d
does that matter
he putting a order in so got to make ny mind up soonish
http://www.meyle.com/html/uploads/techtips/ControlArmBushing_BMW_12.04_us.pdf
300 311 2103
Thats the one, fitted an M5 version of that bush in the past so know they fit........
Ow yes, the lemforder wishbones are the same price as teh Merle ones from autovaux
Can we clarify - which are the part numbers (for both bushes) for the heavy duty BMW equivalents?
I am interested if we can sort out which the right ones are.
Cheers,
Ian
« Reply #20 on: 28 July 2008, 22:10:10 »
I would be interested in these as well.   :y :y
philhoward
  • Staffs
  • Love the engines, so put one in something else..
« Reply #21 on: 28 July 2008, 22:10:31 »
Depends on the grade used - some can flex a fair way if the softer grades
Gotcha!  :y :y :y
Depends on the grade used - some can flex a fair way if the softer grades are used...
iggy21uk - its the grade of Poly which determines the harshness.  The softer versions are virtually indistinguishable from rubber.  Depends on the new vs old grade...Shore is what they use for grading it from memory?
Running an X30XE in a Reliant Scimitar GTE as I can't have an Omega as a company car...
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #22 on: 28 July 2008, 22:25:17 »
Gotcha!  :y :y :y
Shore hardness is a measurement of rubbers resilience. Used to be measured with a dial gauge which pressed a pin into a sample of rubber and registered accordingly. IIRC glass is 100 shore (highest possible as it doesn't give).
TuBy's new whipping boy.
iggy21uk
« Reply #23 on: 28 July 2008, 22:43:30 »
614 035 0016 &
614 035 0010
does that matter
300 311 2103
Cheers,
Ian
[size=11]As I understand it, what I'am going for made by Meyle
VX vertical bush, BMW  HD horizontal bush :[/size]
[size=14]Meyle Omega vertical bush:[/size]
Front axle, left and right
Rear
Lower
Outer Ų 48,5 mm
614 035 0010
Control arm bushing
Omega B Stufenh./Sedan
03.1994 - 07.2003
except: 2.5 D
Omega B Caravan / Wagon
03.1994 - 07.2003
except: 2.6
Price each : £ 5.00 + vat & pp.
[size=14]Omega Meyle Horizontal bush:[/size]
[size=10]Outer Ų 58,5 mm
614 035 0016
Control arm bushing
03.1994 - 07.2003
except: 2.5 D
03.1994 - 07.2003
except: 2.6
Price £9.00 + vat & pp[/size]
[size=14]BMW 5 Series that fit but Heavy Duty Version
.5mm less o/d.
[/size]
[size=10]Heavy duty version
Outer Ų 58,0 mm
 300 311 2103/HD
£9.00 + vat + pp
BMW Heavy duty version that fits
Rear
Lower
Outer Ų 58,0 mm
300 311 2103/HD
Control arm bushing
Limousine (E34)
01.1988 - 11.1995
520 i 24V, 525 i, 525 i 24V
5 Touring (E34)
11.1991 - 01.1997
525 i
7 (E32)
09.1986 - 09.1994
8 (E31)
04.1990 - 12.1999
Limousine (E34)
01.1988 - 11.1995
5 Touring (E34)
11.1991 - 01.1997
525 i
7 (E32)
09.1986 - 09.1994
8 (E31)
04.1990 - 12.1999[/size]
 Don't think VX bushes stock item, order going in this week.
BMW parts maybe?
[size=12]Disclaimer:
This is what I have opted for,  please don't blame me if you go the same route and it does not work out.[/size]
« Last Edit: 28 July 2008, 23:01:24 by iggy21uk »
« Reply #24 on: 29 July 2008, 09:25:13 »
Do you have a UK supplier for those bushes, iggy21uk?
ians
  • Reading
« Reply #25 on: 29 July 2008, 09:36:30 »
So you're going for
614 035 0010
300 311 2103/HD   ?
Sounds like several of us would be interested - would they be up for a volume deal, free postage or something?
I would go for 4 of each.
Cheers
Ian
« Reply #26 on: 29 July 2008, 09:39:40 »
I'd be up for a set. :y
iggy21uk
« Reply #27 on: 29 July 2008, 10:17:01 »
UK supplier  All German Parts, Leeds.
Jason 01132 775245
Order going in 1400 today
Don't know when he will be putting another order in?
Bit confused not sure I you want me to order , thats ok I will
or who wants the poly bushes at the beginning of the thread
Think you best send a PM if want me to order of Meyle bushes
And which ones you want.
« Last Edit: 29 July 2008, 10:37:04 by iggy21uk »
Matchless
  • Nottingham
    • A white van
« Reply #28 on: 29 July 2008, 10:33:54 »
Iggy, check your BMW bushes, make sure that the centre hole is concentric with the outer diameter.
I went down the same path as you a while back, comparing Lemforder, Meyle and GM partnumbers and plumped for a 750iL bush which fitted but had a slight offset. Handling was much sharper but tyres wore on inner edge even though camber was correct. I dont know if the offset is on all BMW bushes or just the one I chose.
When fitting the new bush ignore any alignment or 'thrust' markings...on the BM the bush is behind the axle so takes brake forces as a 'push' whereas the Omega has the bush ahead of the axle so brake forces are 'pulling'. Just make sure they fit in the same orientation as the originals.
ians
  • Reading
« Reply #29 on: 29 July 2008, 10:50:57 »
Jason 01132 775245
Hi Iggy,
Don't want to put you to extra effort, but is it possible to check what Matchless says?   If that is correct, or their is risk, I will probably go for the regular ones.
Is that his order that is going in at 1400, or yours to him?
Sounds like you (set of 4?), me (2 sets of 4), Kevin (1 set) and maybe Scruntie would be interested.
Cheers
Ian
Pages: 1 [2] 3 4 5 6   Go Up
Page created in 0.024 seconds with 16 queries.
