Author Topic: Mtek Chip  (Read 5779 times)
Mtek Chip
« on: 27 January 2007, 18:25:34 »
Well, fitted the chip this afternoon and all I can say is BUY ONE.
The car feels so much quicker off the mark and the traction control is having to work hard infact ive got face ache from smiling so much even the wife asked what have you done to the car  :y :y :y :y
Gwilym
  • Bridgwater, Somerset, UK
Re: Mtek Chip
« Reply #1 on: 27 January 2007, 18:29:48 »
How Much? How easy to fit?
White '00 3.0 MV6 Estate (Ex Met Police Firearms Car)
STMO123
Re: Mtek Chip
« Reply #2 on: 27 January 2007, 18:30:44 »
Only good for pre facelift?
« Last Edit: 27 January 2007, 18:31:32 by STMO123 »
Re: Mtek Chip
« Reply #3 on: 27 January 2007, 18:35:24 »
I paid £125 but that was in the sale which ended on the 15th of January but the normal price is £150 and it took about 10 minutes to fit and you just take the ECU out of the fuse/relay box at the side of the battery, undo the cable clip and disconnect the cable, prise back the cover tags and pull the chip out and push the new one in and reverse the process to put everything back.
MikeDundee
  • Costa Del Peckham
Re: Mtek Chip
« Reply #4 on: 27 January 2007, 18:35:56 »
Yes I can confirm this I Have already e-mailed MTEK last year about, and none for facelifts.
Re: Mtek Chip
« Reply #5 on: 27 January 2007, 18:37:45 »
Should be good for yours STMO, yours is a 2.5 so same engine as pre-facelift.
Admin
Re: Mtek Chip
« Reply #6 on: 27 January 2007, 18:39:30 »
Yep, has to be said, they are well worth the money. :)
I am getting one for the MV6 once little things like the MOT are out the way! ;)
I am going to be very interested to see what effect they have with a manual box!  :D
The Administrator.
Re: Mtek Chip
« Reply #7 on: 27 January 2007, 18:39:33 »
Not quite correct mate, chips are available for ANY Omega with the following engines:
2.5 / 3.0
Not available for:
2.0 / 2.2 / 2.6 / 3.2
MikeDundee
  • Costa Del Peckham
Re: Mtek Chip
« Reply #8 on: 27 January 2007, 18:43:58 »
2.5 / 3.0
Not available for:
Mine is 2.6, stand corected :y
STMO123
Re: Mtek Chip
« Reply #9 on: 27 January 2007, 18:49:31 »
Thanks Tunnie. I might just treat myself, esp now that Pete has said how easy they sre to fit :y
Re: Mtek Chip
« Reply #10 on: 27 January 2007, 18:50:00 »
2.5 / 3.0
Not available for:
Its something to do with the newer engines which makes them much less 'chip able'  i think Vaux got the most out of them really (2.2 2.6 3.2) although i think this is one for MarksDTM to reply to really...
Re: Mtek Chip
« Reply #11 on: 27 January 2007, 18:51:26 »
No problem, i am condering chipping the Senator too, although I need to de-cat it for that  :-/
Admin
Re: Mtek Chip
« Reply #12 on: 27 January 2007, 18:56:44 »
Tunnie, you don't need to de-cat the Senator to chip it. We didn't and the difference was impressive (especially over 4krpm!)
The Administrator.
Re: Mtek Chip
« Reply #13 on: 27 January 2007, 19:00:58 »
I thought the chips where designed to run without the cats?
Paul M
  • Edinburgh
Re: Mtek Chip
« Reply #14 on: 27 January 2007, 19:05:43 »
It's probably more to do with the newer chips being surface mounted rather than socketed, as it's more reliable and cheaper to manufacture. It will have a flashable EEPROM instead that can probably be reprogrammed through the diag socket. So just as "chippable", except you don't do it with a chip ;). In addition to having the appropriate hardware to do remaps, there are almost certainly some additional obstacles to overcome such as checksums etc. Hence why it's much more common to find replacement chips for socketed ECUs than remaps for EEPROM ones.
