Pages: 1 [2] 3  All   Go Down
Author Topic: eBay good service.  (Read 4588 times)
miggcddave
  •   south wales
Re: eBay good service.
« Reply #15 on: 08 April 2009, 14:19:08 »
ive done a load of welding on cars . with just the glass from the mask in tight places like under the wheel arch on the sills  8-) my eyes were ok but i had one hell of a tan on the rest of my face  :D :D
« Reply #16 on: 08 April 2009, 15:38:16 »
I'm not on my own then  ;D ;D ;D
Debs.
« Reply #17 on: 08 April 2009, 15:44:52 »
Auto darkening welding masks are truely brilliant bits of kit!
I`ve just been out and tried it; "fantastic"!!!! :y
Gone is all that vague 'hit and miss' poking about with the end of the electrode to get an arc strike in the "black as pitch" gloom that was the only view I had from my old 'fixed' welding mask.....
A result! :y
« Reply #18 on: 08 April 2009, 15:56:27 »
..... as I found when the battery started working loose. >:( .......
We used to have one where I used to work that had a battery in it. They all seem to use solar panels these days, and if they are left for long periods in a dark cupboard can opps up the coin battery inside them. I 'relocated' an ESAB screen, and when it works it good. However, as I found out, it's best to 'charge it up' with a long blast of stick welding in front of the solar panel.
I found several references to the ESAB screens on tinterweb forums.
« Reply #19 on: 08 April 2009, 15:59:33 »
A result! :y
You needed more practice 'nodding' with your old fixed screen!  ;D  ;D  ;D
« Reply #20 on: 08 April 2009, 16:08:11 »
Well, mine (cheap and nasty from ebay :y) has a couple of AAA batteries and what looks like a solar panel. I believe the panel is just a sensor though.
Screen is fully darkened until you insert the batteries and press the "on" button whereby it lightens fully. It then darkens by a variable amount when it senses an arc. After a timeout with no arc it powers off to conserve the battery.
« Last Edit: 08 April 2009, 16:08:45 by Kevin_Wood »
Weds
  • Chatham, Kent
  • My other hobby
    • Mercedes E class 350 CDi
« Reply #21 on: 08 April 2009, 16:11:37 »
I got arc eye a few times when using the clamp round the head flick down type of shield, you get used to a nod of the head then start to weld, only sometimes the shield stays up in the air and you get a face full of arc !
« Reply #22 on: 08 April 2009, 16:22:38 »
I must admit, I avoided the solar pwoered ones as I know mine will spend most of tis time in a cupboard and hence would be flt when I needed it!
« Reply #23 on: 08 April 2009, 17:47:41 »
With so-many bad stories concerning buying and selling on eBay...I`m just reporting a bit of really good service (for a change):
Bought a B.N.I.B Parweld XR914 auto-darkening welding headshield; `purchased late-yesterday as a B.I.N for £36. with '2nd class signed-for' postage incl.......it arrived this morning at 09.30 with a polite letter of 'thanks for the custom' inside.....what great service. :y
Have you any specific work to do Debs.....................................or is it just to repair your old "colander "of a Miggy.  ;) ;) ;) :y
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #24 on: 08 April 2009, 18:22:03 »
The Gnome prefers using the one I bought.
 ;D
Seriously they make the job so much easier, he won't use the old type now.
TuBy's new whipping boy.
miggcddave
  •   south wales
« Reply #25 on: 08 April 2009, 18:24:36 »
 ;D ;D ;D ;D ;D ;D :y
Debs.
« Reply #26 on: 08 April 2009, 18:38:07 »
 ;D I can`t quite see the road through the floor-pan of the "Pup-Mobile" just yet! ;D
Actually, I`m making a hydraulic log-splitter out of a 8" x 6ft. "H" RSJ, a 20 ton ram (salvaged from an old JCB digger) a 4-port spool valve and some hydraulic "O`s" ;D
It will be 3 point tractor-linkage mounted and should take all the back breaking (and soul destroying) maul-swinging labour out of my yearly 7 tonnes of firewood need. :y
miggcddave
  •   south wales
« Reply #27 on: 08 April 2009, 18:43:53 »
nice work shop debs  that looks bigger than my house  :y
« Reply #28 on: 08 April 2009, 19:15:00 »
I can't weld for love nor money  :-[. Tried it, I'm crap. Arc or Mig.  I'm still proud my grassbox for mower has (mostly) held together...
djm1964
  • Herts
  • The Boys Are Back In Town
« Reply #29 on: 08 April 2009, 20:16:34 »
Blimey , is there anything you haven't got in that workshop Debs? Looks like a real nice Den ,
Take care
Dave :y
Thin Lizzy are still the the best Rock band ever ! R.I.P Phil Lynott never forgotten .
Pages: 1 [2] 3  All   Go Up
