Pages: 1 2 [3]  All   Go Down
Author Topic: Marks DTM  (Read 2915 times)
Re: Marks DTM
« Reply #30 on: 09 April 2009, 19:57:31 »
Every one is free to buy what they want .. :y
And everyone is free to make mistakes ;D
But personally I wish Marks DTM get the best :y
« Last Edit: 09 April 2009, 19:59:35 by cem_devecioglu »
Re: Marks DTM
« Reply #31 on: 09 April 2009, 21:05:57 »
Yes, it is a 1 year old 1.9 CDTi 150bhp (16V unlike the 120 which is 8V) manual Elite mum wagon (Zafira)
Good luck, be prepared for knackerd EGR valves, injectors failing and the car cutting out at all sorts of speeds, poor low down grunt and chocolate gearboxes, that applies to both manual and auto!!
If you chip it the gearbox will last about 45 mins longer than AR25 in a chipped 2.5 TD
Carrying on the great Vauxhall heritage then. :y ::) ;D
Re: Marks DTM
« Reply #32 on: 09 April 2009, 21:34:44 »
I'm guessing Mr DTM will be wanting to borrow the CANdi module for a few days ;D
Re: Marks DTM
« Reply #33 on: 10 April 2009, 00:22:46 »
http://www.omegaowners.com/forum/YaBB.pl?num=1239175488/23#23
Read it carefully ;) :y
Thanks for that :y I can't say anything because I have the Citroen C4 Grand Picasso 7 seater............... and around 50mpg on average, up around 7 mpg since I started using the flashy Total diesel ;D ;D ;D
Re: Marks DTM
« Reply #34 on: 10 April 2009, 07:17:28 »
Certainly will.....not that there is much on it that is not standard fit
Re: Marks DTM
« Reply #35 on: 10 April 2009, 07:22:49 »
Lol.
There are a few known issues.
EGR valve clogging - common across all cars and easily sorted. Worse on short trips.
Particulate filter cloggng - Again, common on all diesels and clogs due to town driving (they have to get hot to self clean)
Dual Mass Fly Wheel - An issue which seems to blight every manufacturer sadly but, a much uprated one was fitted as per late 2007 which so far has seen no failures.
Gearbox - Some very rare issues which occur due to DMF failures. This is a very strong box in reality and used by many manufacturers (Getrag I seem to recall).
Engine seems pretty bullet proof, never heard of any injectors failing or major issues and cant fnd any real evidence of them ether (via the fleet reports or via my local friendly dealer)
Re: Marks DTM
« Reply #36 on: 10 April 2009, 11:58:17 »
Lol.
1.9CDTi engine, same as fitted to Vectras? I know of 2 that had multiple engine related issues, unsure what, as being company car, they just went straight to a garage to fix. Lack of power and dropping to idle (had that last one on a Rover - software issue, but different ecu).  Could well be the fleet servicing routine, or the fact 1 of these Vectra's in particular rarely did more than 3 or 4 miles at a time.
Re: Marks DTM
« Reply #37 on: 10 April 2009, 12:17:48 »
Thats blocked particulate filter symptoms....common on all modern diesels!
Pages: 1 2 [3]  All   Go Up
