Author Topic: indicators in door mirrors  (Read 3285 times)
Re: indicators in door mirrors
« Reply #15 on: 15 April 2009, 13:17:59 »
Would the indicators flash ok with extra lights fitted or would you need a different relay :-/.
If LED based then they would be fine
Just as long as they are not blue!! ;D ;D ;D ;D ;)
Not road legal anyway, but on the OOF it could indicate something special in your sexuality! ::) ::) :D :D ;)
« Reply #16 on: 15 April 2009, 13:24:56 »
Beware of women drivers........................or you won't keep them for long. ;D :y
« Reply #17 on: 15 April 2009, 13:30:39 »
Especially in 4x4's in the car park!! >:( >:( >:( >:( :D ;D ;D ;D ;)
« Last Edit: 15 April 2009, 13:30:52 by Lizzie_Zoom »
r1
  • nottingham
« Reply #18 on: 17 April 2009, 20:44:25 »
no extra relay needed as the plan is to remove the orignal side ones
« Reply #19 on: 17 April 2009, 21:21:46 »
In which case you have to follow a lot of laws and rules.
VOSA should be able to supply the requirements you must meet
Bent valve
« Reply #20 on: 17 April 2009, 21:33:30 »
 Never mind about the door mirrors and LED'S ect, How about getting hold of some old style Trafficators off a 1940's car and grafting them on to your B posts?  they would be sure to get you noticed :y
r1
  • nottingham
« Reply #21 on: 18 April 2009, 10:12:48 »
i know theres a lot of rules thats why i want to retro fit some from another car then i no they are legal.its just to make the car look a bit more 2000 instead of 1998.so i dont think il be taking the option of fitting the semophore ones thank you bent valve
« Last Edit: 18 April 2009, 10:13:52 by r1 »
« Reply #22 on: 18 April 2009, 10:41:25 »
Not necessarily the case...
Taxi_Driver
« Reply #23 on: 18 April 2009, 10:41:52 »
My Viano has them fitted to the door mirrors with no other side repeaters, however it has about 4 leds fitted per side, with appropiate reflectors to angle the spread of light, so you can see them when you stand in front, at the side and slightly to the rear (they have a slight clear plastic dome on the ends to help bend the light backwards.
Big downside tho' is when you have an argument with another van's door mirror, you dont get much change outa £350 from the merc dealer for a new mirror  :o :(
« Reply #24 on: 18 April 2009, 10:44:00 »
Easiest thing would be to get some complete mirrors from a car that does have them, and swap them over.  May need to mod the mounting of the mirror to doo, and may need to fabricate some new mouldings.
Then you need to fabricate something to replace the side ones.
Awful lot of messing around for no gain...
