Author Topic: Another prob?  (Read 4688 times)
Taxi_Driver
Another prob?
« on: 02 February 2007, 21:12:42 »
With my Merc this time......you'll be getting fed up with me soon  ::)
Ok its complaining of glow plug failure....warning light comes on after starting.....i know its good practice to change em all...i dont have a code reader for it so dont know which one it is complaining about?
Is there a way to measure the resistance of them....to identify the faulty one/s ??
Went into halfrauds today to buy a complete set....bout £40 ish.....but they dont have em for my merc  :(
and was told dealer only part......so not wanting to be shafted by merc dealer...id rather just find which one/s have failed and change em  :y
Prolly a question for the diesel omega owners?
Cheers
Timbuk
  • Telford
  • owned a Datsun 120y once!
Re: Another prob?
« Reply #1 on: 02 February 2007, 21:16:44 »
You know you shouldn't say things like that on here TD, it's just asking for trouble ::)
STMO123
Re: Another prob?
« Reply #2 on: 02 February 2007, 21:37:17 »
I'm fed up with you TD >:(
Only kiddin ;)
Taxi_Driver
Re: Another prob?
« Reply #3 on: 02 February 2007, 22:41:07 »
Only kiddin ;)
Thats ok then  :y ;D
No tractor drivers about then  :-/
Markjay
  • London
Re: Another prob?
« Reply #4 on: 02 February 2007, 23:03:27 »
Sorry TD, as you know I burn pure 97 RON, not the oily greasey stuff you call fuel!   ;D
Alas, no more Omegas....
Re: Another prob?
« Reply #5 on: 02 February 2007, 23:04:59 »
drop a V6 in there.... that should stop the glow plugs problem  ;)  :y
Chopsdad
  • Bouncy Castle in Carlisle
  • Keep it clean!
Re: Another prob?
« Reply #6 on: 02 February 2007, 23:08:58 »
Try local motor factors - Halfords cannot expect Merc to have a monopoly on glow plugs surely  :-/ and put in a fresh set - no need to meddle with resistance then  .....  BTW what if you find the dodgy one.... are you going to hand over £20 for a new one  :-?
Markjay
  • London
Re: Another prob?
« Reply #7 on: 02 February 2007, 23:09:37 »
I suggest you try posting the question in one of these forums:
Car Mechanics Magazine (highly recommended): http://www.kelsey-forums.co.uk/cgi-bin/cmm/YaBB.pl
Honest John: http://www.honestjohn.co.uk/forum/index.htm
Mercedes-Benz Owners' Forums: http://forums.mercedesclub.org.uk
MercedesForum.com (US): http://www.mercedesforum.com/
HTH.
Markjay
  • London
Re: Another prob?
« Reply #8 on: 02 February 2007, 23:11:54 »
Did you get the MB P/N off the old plugs?
If you do have the MB P/N, I can try and find out who makes them (prob Bosch or Lucas etc) and see if I can obtain the equivalent OEM manufacturer's P/N for you.
Taxi_Driver
Re: Another prob?
« Reply #9 on: 03 February 2007, 08:26:24 »
If i was keeping the merc, yes i would change em all.....but im selling it and just want to get the warning light to go out.....as im sure a potential buyer will spot the warning light.
Im going to have a go at seeing if i can find the faulty one/ones this morning and then try eurocarparts for them....if i carnt identify the faulty one then yes i will change them all.  :y
Taxi_Driver
Re: Another prob?
« Reply #10 on: 03 February 2007, 08:29:51 »
Havent even taken em out yet MJ....job for this mornning....
BTW i used to be a member of a merc forum......and tbh i get more help from this forum than i did off the merc forum......answers, if i got any where either wild guesses or take it to MB dealer  :(
Essex_Andy
  • Have a guess?
Re: Another prob?
« Reply #11 on: 03 February 2007, 10:29:50 »
I think europarts do merc stuff at nicer prices
If an artic overtakes you, you're driving too slow!!!!!!!!!!!
Taxi_Driver
Re: Another prob?
« Reply #12 on: 03 February 2007, 16:52:00 »
Success!
Engine cover off.....located glow plugs....off with electrical plugs and metered each plug to engine ground....one was 0.4 ohm the others were open circuit....so pretty good proof i had 3 knackered glow plugs and one working one. No wonder it took its time to start in cold weather!
Got replacements from eurocarparts.....got 4 of em....about a tenner each.
Had to buy extended 10mm socket and blimey they were in tight...i was trying not to force them too much in case they snapped...but slowly they did come out with a lot of squealing going on! I did liberally spray wd40 on them 1st....and may of been better letting it soak in overnight  :-/
Anyway they came out and new ones went in ok....bit fiddley with the fuel pipes getting in the way.
Ignition on glow plug light came on then after a few secs went off (as its suppose to do) gave it a start and glow plug light stayed off (as its suppose to do)  :y
So if any diesel omega owners are reading this.....then yes you can test the glow plugs by metering them.....open circuit they're knackered.....reading of about 0.5 ohm and they're ok  :y
Another garage bill saved  :y
Markjay
  • London
Re: Another prob?
« Reply #13 on: 03 February 2007, 16:58:11 »
Result  :y
Now post it on all the Merc forums....  ;D
« Last Edit: 03 February 2007, 17:05:58 by markjay »
Taxi_Driver
Re: Another prob?
« Reply #14 on: 03 February 2007, 17:03:34 »
Result  :y
No post it on all the Merc forums....  ;D
Cheers MJ....be a waste of time....they'd still advise letting MB dealer do the job  ;D
