Project LPG - LEMON :(
Started by JamesV6CDX, 31 January 2007, 13:23:49
QuoteOh dear - so the seller was a total tosser - need to leave interesting feedback about 5 minutes before it times out!!!!
I suppose if you can get it to run it will be worth playing with - what LPG system is installed?
Not yet sure on the make, but there are stickers everywhere "installed by Avon Autogas".
It's definately a sequential, multi injection one.
Martin - if this car turns out to be a pile of crap, what's the feasability of transferring the LPG kit onto a better 2.0? Guessing it would be easy because I could just take the existing inlet manifold across, saving on drilling more holes?
Very feasable, gas will slowly leak away if nearly empty 6 months would lose the rest.
But you will need lots of pipework.
Can you photo the ECU, Evaporator and injectors and I'll see if it matches anything or I can ask a local expert
Of course I can photo it all - but what are you thinking? :)
Martin_1962
Need to know what make it is for spares ect. - I have emailed Avon Autogas to see if they know.
Chopsdad
What a tale.  Can't say anymore  [smiley=tekst-toppie.gif]
Well, I had a look at this car in daylight yesterday, and to be honest, if I get the ignition barrel sorted, and get the engine running, it's not that bad. That bit of trim that's a different colour is making it look very bad, and I could soon replace/respray that.
The bonnet closing issue I now believe is actually to do with the catch, because looking at the bonnet in natural light it's actually OK.
The interior is a little bit grubby, but it's worth bearing in mind that, I have a set of mint leather.
The plan is this:
Try and get the engine going OK, if it won't be costly.
IF I get the engine going, next step is to give it a quick test drive (on a private road of course!) and test it on GAS.
IF it drives ok and runs on GAS, Take it for MOT
IF it passes MOT without much needed, then rip out all the interior, rip out and renew / clean the carpet, and fit the leather.
IF any of the above doesn't happen, then it's back to plan B, which is to remove the LPG kit and find a better Meega to fit it to.
Either way, I have now got a couple of days off, and I finish at 3pm every other day this week, so I'll have a couple of hours each night to tinker - hence hopefully we'll have some more conclusive results by the end of the week at latest!!
x25xe
Good luck with this one - sorry to hear of your troubles in collecting the car.
Hopefully, you will be able to get it running and a new MOT on it. [smiley=thumbup.gif]
