Author Topic: Checked out the Camper today.  (Read 1761 times)
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: Checked out the Camper today.
« Reply #15 on: 25 April 2009, 22:35:08 »
No-one coming past you on the way?
maria
  • Derbyshire
  • I'm proud to be welsh :)
« Reply #16 on: 25 April 2009, 22:36:42 »
Dont know  ::)
« Reply #17 on: 26 April 2009, 07:58:58 »
...... , dont drive or .... :(
Why?  :-? ;)
webby23
  • Nottingham
  • MV6
« Reply #18 on: 26 April 2009, 09:02:43 »
Big City Tyres in Nottingham offer Nitrogen tyre inflation for £2 a corner.
Apparently it stays at the same pressure, regardless of its temperature.
« Reply #19 on: 26 April 2009, 21:06:59 »
Main reasons for using nitrogen are 2 ; (and the reasson most aircraft tyres use nitrogen)
Nitrogen is made "dry" whilst air contains moisture, the moisture content is very susceptible to changes in temperature. It will actually condense out and freeze in very cold conditions so giving a low pressure, but will "boil" off and produce a high pressure vapour when the tyre gets really warm on a long run.
Nitrogen atoms are large in comparison to oxygen, carbon dioxide and water vapour. so they have less tendency to "leak" through the miniscule gaps in the rubber of the tyre and so hold pressure far longer.
So, as said already .. nitrogen tyre pressures are far more stable than those filled with air, especially if you filled the tyre from flat on a humid, wet day.
HTH
« Reply #20 on: 26 April 2009, 21:14:36 »
Well the test drive went fine, think he was quite impressed that I just jumped in and drove it confidently without a thought.  ::) ::) ::) If ti keeps him happy :y
Picking it up on Wednesday night, sort it Thursday eve, get the fridge on etc and York on Friday. :D :D :D
Taxi_Driver
« Reply #21 on: 26 April 2009, 21:44:13 »
But have you got nitrogen in the tyres  ;D ;)
« Reply #22 on: 26 April 2009, 22:04:16 »
Oh, yes, that's what started the nitrogen bit. :y
According to my dad the tyre place he had it done charged £2.40 a corner but calling in for a tyre pressure check and any top up is free for the life of the tyre. :D :D 'Tyre Services' in Darlington.
« Last Edit: 26 April 2009, 22:04:36 by floodm »
