Author Topic: Big Thanks to TheBoy  (Read 1031 times)
« on: 26 April 2009, 20:43:22 »
For taking the time to pop over and have a gander at my bike, sorted the cooling but discovered a indicator light is out and its down to the wiring  >:(
But being an electrical specialist, soon had the problem pin pointed  :y
Also did an oil change on mother tunnies 3.0 Facelift Estate, which was good, as i had never done a paper filter before.
Also fired up my Gas BBQ for a while, and in process is tempting me with the York meet!
Thanks again  :y
Re: Big Thanks to TheBoy
« Reply #1 on: 26 April 2009, 20:50:06 »
what was the problem with the bike in the end?
amigov6
« Reply #2 on: 26 April 2009, 20:54:16 »
Thanks again  :y
You really don't want to miss out on the Yorkmeet. If you don't attend you'll wish you had & we'd all like to see you there matey so stop f*nnying around & start packing your Mig!!!! :y
« Reply #3 on: 26 April 2009, 20:55:24 »
Suspect it was an airlock as i filled it too quick, ran it with the rad cap off, quite a lot of bubbles comming out, so ran it, switch off, fill up, and repeat. Seams ok now but will do a 5 mile run to make sure.
« Reply #4 on: 26 April 2009, 20:55:44 »
Thanks again  :y
I guess i should be my ass in gear i do have all of the gear
« Reply #5 on: 26 April 2009, 22:05:28 »
Thanks again  :y
You're welcome.
Whatever muppet had put the cap on that oil filter needs shooting  >:(
« Reply #6 on: 26 April 2009, 22:06:23 »
Thanks again  :y
You know you need to :y
    • 530D M Sport, 330i Coupe
« Reply #7 on: 26 April 2009, 22:14:36 »
.......Also did an oil change on mother tunnies 3.0 Facelift Estate, which was good, as i had never done a paper filter before.
They are real fun aren't they  ;D When you finally loosen the lid off enough to turn it by hand you find it needs about thirty revolutions and deposits half a litre of oil down your arm!
« Reply #8 on: 26 April 2009, 22:17:08 »
You need a funnel & a length of hose draining into your oil catch tray  :y
« Reply #9 on: 26 April 2009, 22:17:20 »
Sssshhhhh! He hasn't yet worked out why I sent him to finish off removal after I had broken the seal  :-X
