Author Topic: water pipe just burst  (Read 3043 times)
willyboy
  • Leeds. West Yorks
  • Can Do !!
Re: water pipe just burst
« Reply #15 on: 17 May 2009, 10:04:35 »
times like that you want the key to turn it off in the road  :'(
You should be able to shut it off outside your drive/gate  , If you recall i had similar not a massive leak but a leak & they had tarmaced over the stop tap so just put a pick through rough area that it was found it after a couple of goes they came & sorted that later but I managed to then sort out my leak in the house ! :y
nick v6
  • walsall / west midlands
« Reply #16 on: 17 May 2009, 12:33:04 »
ive looked at the bottom of my drive and all around my drive and couldn't find anything
there is a water tap cover in my back garden but when i opened it up it was full of soil and worms
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #17 on: 17 May 2009, 13:12:45 »
in my old estate the water taps were in one central point they had a big drain cover over them but the drain had water cut off or summat stamped on it
also had water meters in it too
a water key can be obtained from B&Q for £13 very useful!
« Last Edit: 17 May 2009, 13:13:20 by tmx »
JesterRT
  • Stafford
« Reply #18 on: 17 May 2009, 13:19:12 »
been in a similar situation - but I dug the soil & worms out with hands and eventually I got to a stop-cock.  kept removing the earth around it and eventually managed to turn it off.
nick v6
« Reply #19 on: 17 May 2009, 13:28:30 »
been in a similar situation - but I dug the soil & worms out with hands and eventually I got to a stop-thingy.  kept removing the earth around it and eventually managed to turn it off.
ill have a dig round later or get the kids to and see if there is a tap down there
willyboy
  • Leeds. West Yorks
  • Can Do !!
« Reply #20 on: 17 May 2009, 16:41:55 »
Its very likely to be tap there Nick , I didnt need a special key it was a std Brass type water shut off & the hole was full of crud worrrrms & the like, you need a rubber glove on & tape it to shirt sleeve or whatever if its that muddy let the kids ladel it out a new game  ::) :y
