Pages: 1 2 3 [4] 5 6   Go Down
Author Topic: project tractor - opps  (Read 8433 times)
Admin
Re: project tractor - opps
« Reply #45 on: 26 January 2008, 17:27:33 »
The suspense, the suspense!!!!
Surely you mean "The suspension, the Suspension"
Max
 ;D ;D
By the way Jaime, at this rate we will be celebrating the 2nd birthday of the forum before we are fully availed of your incident. ;)
« Last Edit: 26 January 2008, 17:28:43 by admin »
The Administrator.
« Reply #46 on: 26 January 2008, 17:54:05 »
Apologies for lack of info - first 2 posts were done from mobile, so short and sweet.
Jimbob pretty much hit the nail on the head on the first page.
For those following the tractor saga will know that in an effort to to stop stripping sump plugs on this stupid bmw monkey metal engine, I fitted a 'quick drain' plug to it. M_DTM helicoiled it to fit.  It hung slightly lower than anything else.
Nipped out to dealer yesterday morning, during an early lunchbreak. So many knobheads driving at stupidly low speeds made me late, so I decided to come back the back way, round the country lanes.
It was going well, until I hit a bump a tad quick, and having a boat anchor for an engine meant that the front came down a bit hard.  This ripped the sump plug out.
I knew exactly what had happened (the noise of the sump plug rattling down under the chassis, and the black cloud in the mirror), so pulled it up quick (in a gravel layby as well :y) and got it switched off before the oil light could come on. Looked for sump plug, couldn't find it.
Got Mrs TheBoy to tow me home, but had to leave on road (drive has a slope, no way could we push it up).
Not wanting it left on the road, I put a spark plug in the sump, put some oil in, and moved it under its own steam on to drive.
Went to Pug dealer to get some suitable sump plugs, which I fitted earlier today.  Put yet another 6.5l of oil, and started her up.  The tractor breaths again.
I shall take out for a spin tomorrow.
Dazzler
  • Haverhill, Suffolk
« Reply #47 on: 26 January 2008, 19:53:49 »
Just think of it as an early oil flush/drain/change :y :D
« Reply #48 on: 26 January 2008, 19:56:44 »
And no need to dispose of the old oil :y
« Reply #49 on: 26 January 2008, 20:01:54 »
I feel for the bikers  :o
davlad22
  • Sunny Yorkshire
« Reply #50 on: 26 January 2008, 20:09:32 »
Yep, he's always saying how we should change the oil every 500yds  ;)
Bad luck pal!  :y
« Reply #51 on: 26 January 2008, 20:10:03 »
good, nothing serious happen.. :)
Danny
  • Wigan, Greater Manchester
« Reply #52 on: 26 January 2008, 20:10:13 »
VERY lucky escape
i was expecting "drove round a corner too quick and car left the road"!
Taxi_Driver
« Reply #53 on: 26 January 2008, 21:14:35 »
Glad it wasnt smacked.......and it ended up ok  :y
I was suprised actually.......now that ive got mud flaps fitted (vx ones)....how easy it is to ground those over bumpy country lanes when your moving a bit.......there has to be about 6in clearance from the road.....thats a lot of movement in the suspension  :o
« Last Edit: 26 January 2008, 21:15:13 by Taxi_Driver »
« Reply #54 on: 26 January 2008, 21:25:59 »
You want to try a Morris Ital with mud flaps then! I ended up with barely any rubber extending under the body and they'd still rub during "normal" cornering.
Mind you, it did have the most appauling suspension I have ever come across.  ;D
« Reply #55 on: 26 January 2008, 21:28:38 »
I had an Ital van for work.  What a heap.  Even on flat ground, throw it in to a bend, the mudflaps would rub on ground...
« Reply #56 on: 26 January 2008, 21:33:33 »
i dont ever again want to try a morris ital.....with or without mud flaps! the memories just wont go away. ive tried counselling and everything! ;D ;D ;D
« Reply #57 on: 26 January 2008, 21:44:48 »
A truly nasty car - but it was free and I was glad of it when I was a student bum. Didn't go too bad really. 1.7 O series engine proved to be pretty much indestructible. Leaked oil like bu66ery (all over the exhaust, which meant it was a bit stinky and threw up a bit of a smoke screen until it all got hot enough to burn off properly). Gearbox whined something chronic in 2nd but was also indestructible.
Bodywork had incredible powers of self-destruction and was welded up and sprayed from an aerosol on a regular basis. 8-)
If you got too enthusiastic with the 78 BHP you'd better hope the road was straight, cos if you over cooked it straight was the only option. :o
Still, put about 50k on it with surprisingly little hassle.
« Reply #58 on: 26 January 2008, 21:49:47 »
Funnily enough, I was in your patch when I had it. Used to live in Elmstead Market.
I do wonder what they'd be like to drive today, in comparison to my current cars. As long as I could dump it by the side of the road and walk home when I'd had enough. I wonder how far I'd get?
Martin_1962
« Reply #59 on: 26 January 2008, 22:00:12 »
I nearly bought one - needed a banger but it was too much for a rust heap
Pages: 1 2 3 [4] 5 6   Go Up
