Author Topic: Suggestions please for a car for a 17 year old  (Read 4585 times)
« on: 22 May 2009, 00:01:50 »
For years I have threatened my youngest stepson that he will be driving a Mini (a real one) when he is 17 :y  Thing is, they are a lot of money, need at least £1500 for anything half decent, can hardly believe it, a Mig is cheaper than almost any Mini :(
Ideas for a cheap and cheerful car, easy and cheap to fix, tax and insure. I am out of touch with more modern cars, but only want to be spending a few hundred pounds. Only one Metro on ebay :o so thinking Ford fiesta, or similar............... :-/ :-/
Edit. i should add that I  may well trade in the Mig for something as it is just sitting there doing nothing, may try a swap......... :-[ :-[ :-X
« Last Edit: 22 May 2009, 00:20:13 by floodm »
KillerWatt
Re: Suggestions please for a car for a 17 year old
« Reply #1 on: 22 May 2009, 00:04:06 »
Nothing is going to be "cheap" to insure at 17, especially on a provisional license.
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #2 on: 22 May 2009, 00:10:39 »
Personally I like Corsa's :y
« Reply #3 on: 22 May 2009, 00:13:49 »
I realise that :'( :'( :'(
« Reply #4 on: 22 May 2009, 00:17:01 »
Don't know whether to spend decent money or not, :-/ thinking cheap, as about a month ago I pulled his mate out of a car he had rolled into a field ::) ::) ::)
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #5 on: 22 May 2009, 00:33:47 »
When i was 17 i had a Pugglet 205 GTi 1.6 it cost £600 and cost £800 to insure lol i smashed that into a field and nearly rolled it!
Little cars that are £500ish and cheap to insure and are reliableish: Seat Ibiza 1.4, VW Polo, Puglet 205 & 106 & 306,Renault clit but dire reliability on older ones!!!,most ford fiesta's 1.25s are still £900+ for good examples,Nissan almera & Micra bullet proof!! theres more but cant think of them right now but theres a few in the list!
i know where theres a lovely Ibiza 1.4 CLS forsale :y its SWMBO's
« Last Edit: 22 May 2009, 00:34:13 by tmx »
« Reply #6 on: 22 May 2009, 00:40:49 »
I think 1.4 is over the car tax bracket???? :-/  Swop for a Mig Estate? :D
si vaux
  • Bangor, North Wales
  • Why is nothing ever easy??????
« Reply #7 on: 22 May 2009, 00:44:21 »
VW Polo or Seat Ibiza = Can't go wrong, Safe, Strong, Normally reliable and if not quite easy to fix, unless it's got a sunroof, I had one of each and both had sunroofs and I would regularly get a wet bottom and a shower on the way to college. Only problem is they hold their value quite well so might be a bit pricey. I'd stick to German reliabilityand solidness as apposed to french crumple zones and electrics problems.
Can somebody point out that it's called North Wales for a reason, lol. Every one of my southern friends always says "How do you fancy coming up to see us or well come down to you." NORTH means up. DOGH!!!!
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #8 on: 22 May 2009, 00:49:38 »
Most important thing on the 1.4 AEX Vw engine to check is HG Failure very common down usually down to a faulty fan switch and check the crank breathers if they block then the crank seal goes but they leak loads and loads of oil when this happens
si vaux
« Reply #9 on: 22 May 2009, 00:51:34 »
Amen to the breathers
« Reply #10 on: 22 May 2009, 00:56:28 »
Bought one of those to go to work and back (5 miles return) about 5 years ago,killed it dead in 2 months ::) :-[,replaced it with a 1.1 205,did exactly the same thing,decided me and small cars arent cut out for each other. :D ;D
« Reply #11 on: 22 May 2009, 00:59:27 »
Thank you for your ideas, as I say, I am out of touch these days. Is there anything that has proper ignition and carb set up, like in the olden day's but modern...... :'( I am not getting into anything with breather problems or ECU's. please just an ordinary engine.
At this rate it could be a 'Series' Land Rover.......... ::) ::)
Swop a Mig for one, anyone..........
si vaux
« Reply #12 on: 22 May 2009, 01:04:40 »
Just remembered I may know of a Ford Ka going for £50 near by all I know is it's got couple months tax just run out of MOT couple of weeks ago. Will try and find out n let ya know A.S.A.P
« Reply #13 on: 22 May 2009, 01:06:59 »
Thanks, but i think that might be too cheap........... :y
« Reply #14 on: 22 May 2009, 01:12:07 »
All cars will have injection/ecu etc nowadays to pass emissions test. :y
Pages: [1] 2 3 4  All   Go Up
Page created in 0.022 seconds with 20 queries.
