Author Topic: abbreviations  (Read 2145 times)
raywilb
  • york. moved to Dalton , Thirsk
    • Citroen C4 Cactus
abbreviations
« on: 11 May 2009, 19:12:54 »
my problem is i whenever abbreviations are used, i haven,t a clue most of the time what they stand for, i would like to see a list with them on. i can understand they may be thousands and to publish one may take ages, so may be on reflection it,s not a good idea  :-[ :-[ :-[
Re: abbreviations
« Reply #1 on: 11 May 2009, 19:20:54 »
there is a brief one under FAQ section.
HTH
 :P
(HTH=Hope That Helps)
Gareth Lewis
  • Glossop, Derbyshire
  • eCommerce and Website Design & Implementation
Re: abbreviations
« Reply #2 on: 11 May 2009, 19:52:00 »
Car specific:
HBV - Heater Bypass Valve
ICV - Idle Control Valve
EGR - Exhaust Gas Recirc
SAI - Secondary Air Injection
EML - Engine Management Light
ECU - Electronic Control Unit
DBW - Drive by Wire (no throttle cable)
CPP - Coil Per Plug
MID - Multi Info Display
CID - Colour Info Display
TID - Triple Info Display
GID - Graphic Info Display
What if you dont't understand the explanation as well ?? :'( :'( :'( :'(
I am such a failure :( :( :(
[size=11]Website: www.online-selling.co.uk
Successful Website Solutions
eCommerce and Website Design, Management & Implementation[/b]
[/size]
Welung666
Re: abbreviations
« Reply #3 on: 11 May 2009, 20:14:56 »
HBV - Heater Bypass Valve - Diverts your hot water to and from the heater ;)
ICV - Idle Control Valve - Does exactly that!
EGR - Exhaust Gas Recirc - Again does exactly what it says on the tin.
SAI - Secondary Air Injection - Noisy unit prone to failing under the passenger front wing :P
EML - Engine Management Light - Orange flashy light telling you you've broken down!
ECU - Electronic Control Unit - Car's brain.
DBW - Drive by Wire (no throttle cable) - Electrickery throttle!
CPP - Coil Per Plug - Vx's way of making you spend 6 times as much when your cam covers leak :y
MID - Multi Info Display -  \
CID - Colour Info Display   \
TID - Triple Info Display     / Date time radio brakelight screen
GID - Graphic Info Display/
That ok for you? ;)
Gareth Lewis
Re: abbreviations
« Reply #4 on: 11 May 2009, 21:08:18 »
That ok for you? ;)
 ;D ;D ;D ;D ;D ;D Nice one!! :y :y
[/size]
kjf7
  • lincolnshire
Re: abbreviations
« Reply #5 on: 11 May 2009, 23:55:03 »
TMI- to much info ;D ;D ;D ;D
raywilb
    • Citroen C4 Cactus
Re: abbreviations
« Reply #6 on: 20 May 2009, 15:40:54 »
thanks guys , yes it will be of help  :y :y :y :y
gstylebaby
  • stockport
Re: abbreviations
« Reply #7 on: 23 May 2009, 04:10:38 »
If unsure mate ask i have to all the time on another forum that i use. ;D ;D
