Pages: 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 ... 17   Go Down
Author Topic: Off with its head (s)!!!  (Read 31391 times)
Re: Off with its head (s)!!!
« Reply #90 on: 08 March 2009, 23:00:31 »
so I deserve to be the most stupid member medal ;D :y
Is Otosan still a company? Maybe cheaper motoring.  ;D  ;D :y
« Reply #91 on: 08 March 2009, 23:01:52 »
Thanks for your interest, good night :y
HerefordElite
  • Hereford
  • Welcome to the Shire
« Reply #92 on: 08 March 2009, 23:09:34 »
good news Mehmet exchange rate is better at moment 750TRY = only 296GBP  :D
Sure anyone on here would sort parts and postage for you if you need bits :y
problem is the GBP part is fix TRY part changes so they profit more :-[
oh sorry got the exchange rate the wrong way round :-[ £350 is 885TRY :o :o :o
Just ask on here and i for one would be happy to try and source bits for you :y
« Reply #93 on: 08 March 2009, 23:46:30 »
so if i read correctly, leaking  stem seals are a possible cause re pre cat issue, and Micks car has an inferior item fitted from the factory?
And its not necessarily down to mileage/use/thrashing when the dreaded 0420/30 appear?
If so any idea on which engine numbers are likely to be effected by these/how long where they in the production run? Can they be told apart by part number from other drive by wire cars. In short, how to tell if an individuals car would be effected with these stem seals?
When your ready... I can see your busy:-)
Looks like fun though.
M0T0RVATE
  • Orpington
    • 94 Omega Elite Saloon 3L
    • MOTORVATE STUDIO
« Reply #94 on: 09 March 2009, 00:42:04 »
i have just rebuilt mine mark with facelift manifolds ported the heads on exhaust side put 4 g cams in junked the egr and sec air inj system heads were refurbed skimmed all new inlet valves new valve seals all valves re lapped runs sweet and does have a lot more go in it !  :y
While having a look around my '94 3.0L, I discovered that the secondary air injection system is already removed, (well most of the main parts...lol)...
I am also going to remove the EGR system completely.
Is there a blanking plate for the intake plenum, or do I just fabricate my own, as originally planned.
Only had my Omega about 6 weeks, so still needs a few bits sorting...
Martin_1962
« Reply #95 on: 09 March 2009, 07:59:29 »
All DBWs until 2002 AFAIK
« Reply #96 on: 09 March 2009, 08:29:56 »
Ok, stripped a head down today.
Here is a pic of the trouble stem seals.
The green one is the standard Vx stem seal as used throughout the 2.5 and 3.0 production run plus most of the other big block 4 pots to!
The red one is the issue, it is vey hard and I could simply pull it off the guide with my fingers (compared to the ones on TB's old heads which required special pliers and brute force to shift even at 10 years old and 100K+ miles).
Now these came into existance because some low life, sorry purchasing person, decided to try to save a penny a seal by using an alternative which had not been proven!. I trust they were sacked, fired and buried for that one!
Here are all the removed items, these will be soaked in caustic soda for 24 hours before having a good hot rinse and final clean in an ultrasonic bath.
And the head, this will gently 'bleed' old oil until I get a chance to pressure wash it down ready for a bit of 'touching in'
About 147k :y
So is it just the 2.6, or 2.6/3.2 fitted with these, and is it all of these engines or just a subset (I guess at the moment we don't really know?)
« Reply #97 on: 09 March 2009, 08:31:41 »
I have a question in with GeffD on this one!  :y
« Reply #98 on: 09 March 2009, 09:10:16 »
how many miles on Micks car, just out of interest?
And are these seals likely to be prematurely effected by alternative fuel like lpg?
« Reply #99 on: 09 March 2009, 09:35:47 »
I dont recall, about 100K ish.
They are bad though, I have never before been able to remove a stem seal with my fingers and the valves just fall through them once the collets are removed!
It appears as if the rubber is not oil tolerant which is pretty piss poor given where they spend there working life!
Might get a few valves cleaned up tonight so will post some further pics.
Might also get the head initialy de-greased ready for some work.
« Last Edit: 09 March 2009, 09:36:33 by Mark »
MikeDundee
  • Costa Del Peckham
« Reply #100 on: 09 March 2009, 09:38:20 »
Kepp up the good work Mark :y.....just one query though, thought you were just gonna keep an eye on the tyre pressures :-X.....why's the engine in bits :-X ;D
Ow bugger, forget to do the tyres!
Not a problem though, there on ebay so will have a new owner shortly!
Ahh, thats Ok then,  :-?......I can stop drinking now, had me worried there for a minute ;D
MikeDundee
  • Costa Del Peckham
« Reply #101 on: 09 March 2009, 09:38:58 »
Mileage is just under 120k :y
« Reply #102 on: 09 March 2009, 10:14:10 »
If this work does not make a difference to the running of your car Mick, I will be very surprised!
« Reply #103 on: 09 March 2009, 10:38:24 »
Can you remember the mileage when the cat code first came on? Probably a better indication of the seals life.
Martin_1962
« Reply #104 on: 09 March 2009, 10:40:20 »
I asked around a while ago
Started with DBW - for about 1 year AFAIR
GeoffD reckons +18bhp from 3.0 cams
196bhp
How much from some gentle porting?
« Last Edit: 09 March 2009, 10:44:59 by Martin_1962 »
Pages: 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 ... 17   Go Up
Page created in 0.023 seconds with 20 queries.
