Pages: 1 [2] 3  All   Go Down
Author Topic: multiplug connector..  (Read 4611 times)
iainb
  • West Midlands
Re: multiplug connector..
« Reply #15 on: 21 May 2009, 22:43:11 »
How many wires will the connector have (male & female)?
Does it need tobe water proof ?
Omegatoy
  • UK
« Reply #16 on: 23 May 2009, 08:03:47 »
take a trip down the scrappy and cut off the ones you want both male and female!! or find someone breaking a motor ?? :y
This is for the bike  :)
male/female leccy connectors for the rear light cluster are all corroded.
yep knew that but there are hundreds of cars with any number of different sized connectors so you could get the one you need easily be it 3 owre 4 wire or 10 wire!! all of which will handle brake lights and indicator voltages easily :y
« Reply #17 on: 23 May 2009, 09:28:39 »
Thats true, did not think about that.... off to the scrappy then :)
« Reply #18 on: 23 May 2009, 16:55:57 »
right fixed it!
I decided not to use connectors, as i don't have the crimping tools to make the metal connections which actually go in multi-plugs.
So i decided to hard wire, i used long lengths which allows me to put the light cluster on the ground when replacing blubs!
It actually came out quite well, was surprised by my soldering skills, wrapped it all up in insulation tape, did the same thing for the number plate light, so its all working again  :)
« Reply #19 on: 23 May 2009, 18:04:12 »
right fixed it!
oh dear, oh dear, oh dear  :-X
« Reply #20 on: 23 May 2009, 18:21:25 »
right fixed it!
I had heat shrink, but nothing to hear it with  ;D
  • Online Online
« Reply #21 on: 23 May 2009, 18:23:18 »
right fixed it!
A lighter does the trick if you're stuck, you have to be very careful though.  ;) :y
« Reply #22 on: 23 May 2009, 20:04:59 »
right fixed it!
Your mum's hairdyer....
« Reply #23 on: 23 May 2009, 20:06:24 »
right fixed it!
At the end of the day why is heat shrink so much better than insulation tape??
  • Online Online
« Reply #24 on: 23 May 2009, 20:20:13 »
It's not if you don't have a free end of wire/cable to slip it over!  :y :y
« Reply #25 on: 23 May 2009, 20:31:09 »
Just make sure you slip it on before joining the wires together.. :y :y
« Reply #26 on: 23 May 2009, 20:33:50 »
right fixed it!
In the case of where yours is, its more splashproof for a start
    • 530D M Sport, 330i Coupe
« Reply #27 on: 23 May 2009, 20:34:21 »
right fixed it!
I tend to use the soldering iron  ::)
« Reply #28 on: 23 May 2009, 20:36:13 »
right fixed it!
I wrapped up each cable after i soldered them together, then wrapped both together, i continued it up the main cable. I also used an old wire from a soldering iron! The tip was broke so i cut off its power cord, and used that to extend the wiring.
« Reply #29 on: 23 May 2009, 21:35:18 »
Beats buying a new tip any day.  ;)
Pages: 1 [2] 3  All   Go Up
