Pages: 1 2 [3] 4 5 6 7   Go Down
Author Topic: Project Heads Off  (Read 10608 times)
0 Members and 3 Guests are viewing this topic.
Martin_1962
Re: Project Heads Off
« Reply #30 on: 23 May 2009, 19:16:43 »
CTP trapped by oil cooler pipes - I cannot get a crow foot spanner, so what to do about the cooler pipes?
it will come off without removing oil cooler pipes normally, but if not, you will need so crowfoot to remove oil cooler pipes
Don't have one of those :(
Does anyone near WOrcester have one?
Head 135 is off that pipe is loose
Will be taking off 246 before refitting coolant pipe
Nope sorry, but there is a Machine Mart in Worcs  :)
My transport is in bits :(
Martin_1962
« Reply #31 on: 23 May 2009, 21:03:02 »
Well left it with one head off, lots of plumbing disconnected, loose coolant pipe, thermostat off coolant pipe from thermostat broken off bastard bolt.
Oil is draining - so cleaned the rear breather box, but the breather pipe with the valve on has come off from where it was?
Will whip off 246 in the morning (if possible), and then refit 135, coolant pipe, Coolant hoses, heater hoses, and HBV.
I used a spark plug socket on the down pipes, but have no idea how I wil reconnect.
Last job before putting away tools was to start removing the exhaust manifold and first in morning is to fit the new head with the followers.
There is supposed to be something else to move on the heads but not sure what it is.
Martin_1962
« Reply #32 on: 24 May 2009, 07:49:42 »
Restarting in a minute - just finishing my breakfast
Martin_1962
« Reply #33 on: 24 May 2009, 12:06:03 »
Head 246 removed, oil filter removed from top, oil cooler changed, new thermostat fitted.
I am now going to refit head 135. 8-)
« Reply #34 on: 24 May 2009, 12:06:58 »
Martin_1962
« Reply #35 on: 24 May 2009, 12:29:40 »
135 is waiting until after dinner now
Martin_1962
« Reply #36 on: 24 May 2009, 15:44:59 »
135 is fitted, as are its A & G cams.
Covers to do, oil pipes refitted.
Next job involves the angle grinder when I have found it.
Hot, feeling faint - will not finish today :(
webby23
  • Nottingham
  • MV6
« Reply #37 on: 24 May 2009, 16:01:12 »
Very interesting posting Martin keep it coming mate
« Reply #38 on: 24 May 2009, 19:04:10 »
Get some rest..nobodys keeping chronometer.. :y
Martin_1962
« Reply #39 on: 24 May 2009, 19:52:57 »
Just finished for today about 11 hours and I still have  a lot to do.
Absolute agony - back has gone and lots of cuts on my hands.
Still have plumbing at the back to reconnect, CTP, L/H exhaust, coolant bridge (and I have lost my washers), inlet divider, backing plate, cam wheels, timing belt, inlet manifold, plenum, oil & water Sue is stir crazy and I am well fed up!
« Reply #40 on: 24 May 2009, 19:57:27 »
I think its a priceless experience :y
plus a good working healthy car as a bonus at the end..
Martin_1962
« Reply #41 on: 24 May 2009, 22:46:24 »
Found the coolant bridge washers.
Still dreading tomorrow - it will be raining later (I hope I finish before)
Martin_1962
« Reply #42 on: 24 May 2009, 22:48:17 »
There alerted - I have requested a Mark DTM - I hope this new feature works!
    • 530D M Sport, 330i Coupe
« Reply #43 on: 24 May 2009, 22:48:56 »
Have you got a gazeebo? might save you from getting soaked!
Martin_1962
« Reply #44 on: 24 May 2009, 22:52:44 »
No - got a caravan though ;D and my garage is too small and too messy.
Pages: 1 2 [3] 4 5 6 7   Go Up
