Author Topic: Fitting Electric Shower  (Read 3077 times)
« on: 28 May 2009, 20:38:30 »
Hi Guys, Fitting an 8.5Kw (cheapo Triton) shower for a mate`s mate. 15 metre pretty much straight run from consumer unit. Is 6mm cable gonna do or will I have to up it to 10mm. TIA
Ziad
  • Bahrain
Re: Fitting Electric Shower
« Reply #1 on: 28 May 2009, 20:46:02 »
I'd suggest you go with the 10 mm wiring. I do not trust these thing on a 6 mm. The wires tend to heat a lot when in use IMO on the 6 mm.  :-/
« Last Edit: 28 May 2009, 20:46:40 by ziad »
Gareth Lewis
  • Glossop, Derbyshire
  • eCommerce and Website Design & Implementation
« Reply #2 on: 28 May 2009, 20:52:37 »
Would you like me to ask one of the builders who have been here 9 BLOODY DAYS fitting an electric shower in our house!! >:( >:( >:(
Supposed to be a 5 day job to convert shower room to a wet room type and to get the shower off the combi boiler onto its own power and water supply.
I could have done it quicker myself ;) ;) ;)
[size=11]Website: www.online-selling.co.uk
Successful Website Solutions
eCommerce and Website Design, Management & Implementation[/b]
[/size]
miggcddave
  •   south wales
« Reply #3 on: 28 May 2009, 21:11:27 »
do you now the regs on fitting a shower .rcd switch earth cable thickness shower switch with pull cord earth cable on all pipe work ? if you are not sure mate get a spark to fit it if it goes wrong a shower will kill :( :(
« Reply #4 on: 28 May 2009, 21:16:50 »
Yeah, I know all that mate, 45A MCB @ consumer unit, 30ma RCCB protecting the circuit and a 45A double pole isolating pull cord/switch. Just wondering whether the 6mm T/E will de-rate due to the cable run. :y
miggcddave
  •   south wales
« Reply #5 on: 28 May 2009, 21:21:30 »
yea that sounds good to me mate but i would use 10mm T/E just to be on the safe side; and if you up grade your shower in the future you got the cable to take it  good luck mate :y
« Reply #6 on: 28 May 2009, 21:23:45 »
Thought about that. 10mm it`s gonna be (bloody dear though), ah well, what price safety & peace of mind :y
miggcddave
  •   south wales
« Reply #7 on: 28 May 2009, 21:27:58 »
have you had a look at screw fix direct good prices in that book ; worth a look its on line  :y
« Reply #8 on: 28 May 2009, 21:34:22 »
I`ll have a gander. Usually get most of my stuff from "Toolstation" :)
miggcddave
  •   south wales
« Reply #9 on: 28 May 2009, 21:46:30 »
25 mtr reel for £48 10mm t/e in screw fix with vat :-/
« Reply #10 on: 28 May 2009, 21:47:47 »
Same bloody price @ the Toolstation :'( :'(
miggcddave
  •   south wales
« Reply #11 on: 28 May 2009, 21:50:59 »
oh well ? but like you siad safety first
KillerWatt
« Reply #12 on: 28 May 2009, 23:10:14 »
That's double pole isolator with indication, and you need to be Part P for anything concerning a bathroom.
It's more than just cable length versus current drain when carrying out an installation.
Seriously, get a qualified sparks in.....because a mistake can see you in the dock for manslaughter if something tragic occurs.
crazyjoetavola
« Reply #13 on: 28 May 2009, 23:13:13 »
Wise words Killer :y :y
miggcddave
  •   south wales
« Reply #14 on: 28 May 2009, 23:13:40 »
well siad K W thats the words i was looking for  :y
