Author Topic: Ball-joint splitters  (Read 1788 times)
bestseany
  • Flintshire, North Wales
« on: 13 February 2007, 09:33:44 »
What is the best type of ball-joint splitter to get, namely, one for removing the wishbones with.
Is it best to get one that looks like a chisel, and you just hit it with a hammer, or ones of those splitters that have a nut and thread that you turn with a spanner?
familyman
  • Sittingbourne, Kent
Re: Ball-joint splitters
« Reply #1 on: 13 February 2007, 09:46:23 »
A really really big hammer to shock the joint:y :y :y
No seriously from a profesional point of veiw the screw type when using it if the bolt has gone eally tight and joint not popped a tap with a hammer will usually finish the job.
the problem with the fork type is that they normally end up damaging the the ball joint rubber, MOT failure follows :y
You came in that, your braver than i thought
bestseany
« Reply #2 on: 13 February 2007, 10:02:51 »
Well, the wishbones would be getting replaced anyway. Does a screw type actually make the job easier than the fork type?
familyman
« Reply #3 on: 13 February 2007, 10:10:09 »
The fork type is certainly quicker especially with a big  hammer and a good right arm just watch your thumb knuckle if you miss!!!!!!!!!!!!!!!!!
The screw type would be better long term i.e. for removing track rod ends to be reused etc...  :y
Markjay
  • London
« Reply #4 on: 13 February 2007, 10:18:26 »
I have always used the fork type, they are more universal - with the screw type you need to have one with the right reach, height, etc so could be a pain to find the correct one for the car.
Alas, no more Omegas....
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
« Reply #5 on: 13 February 2007, 13:10:00 »
despite breaking my last fork set i have since replaced with a similar but better make of the same. Forks for me  :y
sounds2k
  • Queenborough, Kent
    • Saabs and a Jag XFR
« Reply #6 on: 13 February 2007, 13:26:20 »
well for removing track rods, use one of these - works perfectly and doesn't damage the rubber boot. An alternative is one of these, but when a mate and me tried to get the track rod out on my old miggy that one didn't work - wasn't big enough so kept coming off when you did the screw up. Ended up using the fork type and it was a major pig to remove.
I used the first type (scissor) when swapping the track rod on my current one, the scissor type did it first time in about 30 seconds, laughably easy with that  :y
