Jaime and Tunnie and Martin Imber...
Started by JamesV6CDX, 14 February 2007, 07:53:47
Also, will you really help me fit the seats in?
I'd find that so much easier, with three of us, I've never done them before, and I'm hazy about the electrics/memory etc...
QuoteAlso, will you really help me fit the seats in?
Yep no problem, i'll lend a hand. It makes sense fitting it there and then with 3 of us. Should be done in no time  :y
Besides i doubt it will all fit in 1 car, hence Jamie coming too. Really appreciate Jaime coming up too, I doubt it will all fit in the Senny.
I am considering buying cambelt kit, and waterpump and maybe fitting that Sunday too  :-/
QuoteWhat's happening then Jaime/Tunnie - Are you both going up to Nots on Saturday?
I believe so...
I believe so...
If thats ok Jaime? Do what we did last lime leave early!  :o Get up there do the springs then on to get the seats, as long as thats ok with Mark?
James - That t!t of a seller defo got those seats ready?
I believe so...
Will confirm 100% as soon as I can get him, hopefully tonight!
if i get full cambelt kit for 2.2 & water pump, how long do ya rekon it would take. Have time on Sunday?
Quoteif i get full cambelt kit for 2.2 & water pump, how long do ya rekon it would take. Have time on Sunday?
I reckon that may be a bit too ambitious
1 hour 20 minutes.....just mark the old water pump position before you remove it as it seems to be hit and miss if the blocks have the locators on them....
Auto Addict
Where's all this happening, tunnies or TheBoys, might have some spare time on Sunday if you want an extra pair of hands.
If not, tell me to sod off. :(
I like red cars
nixoro
#24
Have you got pieces of loom with connetors coming with the seats if not you'll need some extra wiring and some flat connectors to connect onto the memory box and also a nylon block.
Have you found the wiring diagram for wiring it up yet, I used 1 I think was created by a member on here cant remeber but shall try find it for you.
Somewhere in the thread below it shows the wire connections to the box, the rear seats and passenger should connect using the original connectors like mine did if your lucky.
http://www.omegaowners.com/forum/YaBB.pl?num=1154467767
Good Luck with the install.
QuoteWhere's all this happening, tunnies or TheBoys, might have some spare time on Sunday if you want an extra pair of hands.
I am guessing Jaimes, cause my garage is full of cars (wtf?)  ;D
Seriously though be at Jaime's place since the Rover needs work.. however it can be at mine if required....?
Be Omega city on my drive, Dad's 2.2, my 2.2, Jaime's MV6, AA's 2.2, James 2.0!  :D
Your welcome to come down to AA....flood my drive with 2.2 Omegas  ;D
Auto Addict
Let me know where over the next couple of days, if it's at yours, PM me your address, I know where Jaime's is.
I like red cars
I am just down the road from Jaime, about 1/2 mile. As long as this stupid seller has the seats, and James can come up on Sunday can't see why not.
I better give the 2.2 a clean, its a bit mucky atm!  :-[
Ok, guys, please don't take 2 cars all the way to Nottingham just on My account. that would really not be a good use of your fuel and time....
Tunnie, if all goes well then 1.5 hours should be about right for your belt kit, BUT....
We need longer than that. Why? To remove the rear cover, and have a stab at that sheared bolt....
So probably a job for a longer day...
MaxV6
Last time I took a full seat set in a saloon it was like this.
Rear bench pieces in boot, at an angle...
Front seats moved all the way forwards, and sat up,  and the "new" front seats put in behind them facing down and backwards , with cardboard protecting the rear of the existing front seats , and the headrests over the rear parcel shelf...
this was in a senator though.,
then a VERY uncomfortable drive for 65 miles to get them home....
Max
