Pages: 1 2 [3]  All   Go Down
Author Topic: Will Omega seats fit in Omega  (Read 7500 times)
Re: Will Omega seats fit in Omega
« Reply #30 on: 16 February 2007, 13:56:53 »
Have you confirmed the seats are actually ready this time?
« Reply #31 on: 16 February 2007, 14:17:41 »
Yep, called the guy at lunchtime. He promised collection is fine tomorrow.
Tunnie has all the info.
If he lets you down, drive the Sennie into his lounge window........
« Reply #32 on: 16 February 2007, 15:35:15 »
So, back to original Q, will Omega seats fit in Senny, and will there be room for Senator?
Tunnie - send me a text msg to let me know whats happening, as I won't be online tonight...
« Reply #33 on: 16 February 2007, 15:47:34 »
I can't answer about the seats fitting, I've never done it
I'll let tunnie liaise with you about the plans, and keep me informed.
I'll be online again Saturday night probably, hopefully with a rover timing cover...
MaxV6
  • Oxford UK
    • 2.2SportPremium Jag est
    • Work related forums....
« Reply #34 on: 16 February 2007, 15:57:46 »
I thought I'd already replied about senny carry capacity.... but can't now find the post...
ANYHOW...
I got a full set of Senny Seats in to the back seat & Boot of a Senny...
given that I think they're wider than Omega seats...    you shouldn't have a problem... the only trouble is adjusting them to actually fit the space  if they're electric...
I'd knock up a lead to a ciggy socket connector and make a note of the pin positions for the seats, then just power them when necessary to change the shape to get them in and out of the car.
I got the 2 parts of rear bench seat in the boot at an angle, and the 2 front seats went into the back seat, with the headrests over the parcel shelf and the seat base pointing "down" into the rear footwell....
angle adjustment was a required to get the second seats in....  and I had the Senny's own fronts seats moved virtually all the way forwards...
a bloody uncomfortable drive home though.,..
Bet you wish you had the stretch senny limo now eh Tunnie ;)
« Reply #35 on: 16 February 2007, 22:16:29 »
right update.... going tomorrow nice and early!
If i remove the rear bench on the Senator, will i fit the Omega Interior in the Senny, with a passenger up front?
The front seats are leccy so i may not be able to adjust them!
I see it going in 2 ways....
Rear Bench in the boot (both parts) at an angle (thanks max) door cards in there too. Front seats in the back.... even more room with the rear bench removed.
Or rear bench in the back along with cards and front seats in the boot  :-/
Btw is the Senny rear bench easy to take out as Omega?
« Reply #36 on: 16 February 2007, 22:20:51 »
It comes out the same way, pull the 2 toggles at the front edge and lift. The Omega seat belt clips seem to hold on the seat base harder on the Omega than on the Senator.
« Reply #37 on: 16 February 2007, 22:44:48 »
just popped out and yep its easy, just as described pull the toggles and its off.
I am thinking front seats in back of senny, as if they were in the front, bolts facing down... should go in. Rear bench in boot
« Reply #38 on: 16 February 2007, 23:00:29 »
I can't really remember how it went in but I've seen a complete interior of a Carlton in a Carlton. But IIRC one of the front seats was upside down 'in' the front seat and t'other was also upside down in the back. I assume that the back seat base & back was actually on the back seat. I might be talking a load of bolleaux though  ::)
« Reply #39 on: 17 February 2007, 07:45:53 »
we will soon find out, if there is no room TheBoy can sit in the spare seat, fit some wheels to it and I can tow him behind me  ;D
« Reply #40 on: 17 February 2007, 17:57:34 »
It fits....  ....even with a fat boy like me in....
Mission accomplished :)
« Last Edit: 17 February 2007, 17:57:55 by TheBoy »
« Reply #41 on: 17 February 2007, 18:13:06 »
Yup surprised at how easily it all went in. For the record...
We used my Senator in the end. with the rear bench removed (just pull 2 toggles)
2 main backs of the rear seats on the boot floor. Rear bench in at an angle, all door cards in on top of it. With 2 head rests.
Fronts seats in upside down in the rear, my seat luckily could go back as normal passenger one fully forward because we had it all the way forward when we removed the bolts.
Pages: 1 2 [3]  All   Go Up
