Pages: 1 [2] 3  All   Go Down
Author Topic: A rare sight on the mainline!  (Read 2803 times)
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: A rare sight on the mainline!
« Reply #15 on: 01 July 2009, 20:08:15 »
Seems wed have a few "Fat Contollers" on here  ;D ;D ;D :P
« Reply #16 on: 01 July 2009, 20:20:33 »
Me fat??!! :P :P  Never ;D ;D ;D ;D ;D ;D ;D ;)
Stokie Steve
  • Stoke on Trent
« Reply #17 on: 01 July 2009, 20:58:35 »
Don't worry Mark, I have found this info on the Class 52 Western's:
"The Western locomotive has two 65 litre Maybach MD 655 diesel engines each driving a Voith hydraulic transmission, which turn the wheels via a gearbox. The cylinders are arranged in a V formation driving a common crankshaft. The Maybach diesel engine has 12 cylinders and produces 1380 hp at 1,500 rpm. Maybach diesel engines were also used in marine installations such as motor torpedo boats and fishing boats."
 ;D ;D ;) ;) ;) ;)
Probably still more economical than my car... :-?
Macduff
  • Bedfordshire
    • Omege 2.6 CD
« Reply #18 on: 01 July 2009, 21:18:14 »
Don't build em like that any more :(
Mores the pity
Born free taxed to death
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #19 on: 01 July 2009, 21:25:51 »
Me thinks that the Westerns had Voith 'Mekhydro' transmissions ......... anyone?
« Reply #20 on: 01 July 2009, 21:28:42 »
Well they certainly had "Voith hydraulic transmission" ;) ;)
« Reply #21 on: 01 July 2009, 21:47:20 »
Nope, they were warships.....the Mekydro transmissions for the more powerful westerns would not fit in the uk loading gauge hence voith ones were used
Martin_1962
« Reply #22 on: 01 July 2009, 21:55:20 »
Mekhydro is a 4 speed auto, used in Hymeks and some Warships
Westerns and the rest of the Warships use a multi torque converter system, which empty and fill at different speeds.
http://www.geocities.com/wbd641/HydraulicLocoTrans2.html
« Reply #23 on: 01 July 2009, 21:58:10 »
Mekydro I beleave is the correct spelling   :P ;D ;D
Seth
« Reply #24 on: 01 July 2009, 21:59:21 »
OOPS, you're indeed correct Mark!
In fact, our entire 'Valleys' fleet of DMU rolling-stock has Voith 'turbo-transmissions'. Bloody reliable too, especially considering the thrashing they get on our services - 17 stops between Cardiff and my home depot at Treherbert alone - in a scheduled journey time of 64 minutes. I've not heard of one failure in 11 years!
I'm quite a fan of the class 150/2 Sprinter - 14-litre Cummins with Voith is an excellent combination. Total route availability too.
« Reply #25 on: 04 July 2009, 19:13:55 »
Well, yesterday I was at East lancs to support 47292 in the hope of a good day with some cab rides etc.
Anyway, when 47292 arrived after her jaunt up the mainline, there was a major coolant loss problem!
I arrived in Bury at 8.30am (after a 2hr drive) where we inspected the coolant group on her.
Sadly, this was all ok!
So, we removed a few elements and could see water pouring off the bottom of the header tank!
At which point it was out with the header tank which involves removing many hard to get at internal pipes, extracting some vent pipes which were all seized solid and then craning the bloody thing off!
At which point we could then clean up all the gasket mating surfaces, re-tap some of the holes, replace some damaged pipes and re-fit the whole lump.
By which time it was 8.00pm
So the only part of the East Lancs railway I saw was the diesel shed.
There was also an issue with the Western, the delight that is the twin engine voith based traction system threw a wobbly.
The gearboxes on this have just been re-built by Voith at a cost of 38K each....anyway, they had a little issue which brough the old girl to a halt (simply put, one end was trying to go forwards whilst the other was trying to go back!).
So, that was also looked at by the Western team (using my tools etc).
It was nice to have a good close look at a running Western and get a full walk through. They certainly have a nice diesel pre-heat setup!
I got home at 1.30am this morning..........thankfuly having got some what cleaned up because I looked as filthy as Clarkson did last wee when he arrived in Edinburgh having spent the day on Tornado!
« Last Edit: 04 July 2009, 19:16:29 by Mark »
« Reply #26 on: 04 July 2009, 20:23:27 »
That sounds like a very interesting and productive day Mark :y :y :y
« Reply #27 on: 04 July 2009, 20:31:35 »
Sadly, I am paying for it today.
Tired and stiff....think I need a bath!
Those Warships are an absolute shite to work on!
Debs.
« Reply #28 on: 04 July 2009, 21:43:16 »
 :y Mmmmmmmmmm Brush-Sulzer 'eye-candy'....`smashing pic Mark. :y
I have a love of class 47`s: my buddy has 47449 (aka D1566) just up the road from here. ;)
« Reply #29 on: 04 July 2009, 21:51:31 »
Ah yes, the Llangollen diesel group, that one has ETH fit.
They are about to move the class 46 away from Llangollen......and there are a few possible destinations.....and there is one particular one I hope it goes to.
Pages: 1 [2] 3  All   Go Up
