Paperclip test ??
Started by lukie, 21 February 2007, 20:56:39
QuoteBackside comments?  You're leaving youself wide open.
Oops, there I go again :-[
;D ;D
Well I will close any possible opportunity's, she went to my uni and was in the year above!!  ;)
And does she know?
;D ;D
And does she know?
Only a topic on paperclip tests could end up on this!  ;D ;D
I think so, been out for dinner with her a few times, been to her flat. She has just moved again. She is now living in Surrey, and works in central London.
I went and saw her at Made in Brunel, her project was very good. She said that she would visit me when I go too...
Its hard to tell what she is thinking (like all women!)
QuoteI think so, been out for dinner with her a few times
Even for students, taking her to McDonalds doesn't count.... ;D
QuoteIts hard to tell what she is thinking (like all women!)
Yeah. Imagine the riches awaiting a man who can design a fault code reader for one of those :o
Martin_1962
Try to impress her with your cars ;D
Tunnie, you dark horse....
STMO, you're right, you can't sh*g an Omega, but they're great for sh*gging in ;D
ClarCE
lol, harsh.
So Far - :: Re-Finished Elite Wheels :: Black Leather Interior :: 3.0 Cams :: Chipped (REMOVED, EBAY SHI*E) :: Facelift Skirts ::
To Do   - :: Facelift Rear Bumper, Door Mouldings :: Irsmsher Front Air Da
lukie
by chance I have figured out my EML problem, it is due to the gas conversion, I have ran now 500 miles purely on gas so the EM has lowered the oxygen sensor reading, therfore when running on the expensive stuff my car complains (and it's not the only one  ;D)
will have to run around for a few miles on petrol to sort it out, but just to note this is only happening as my car runs on a single point LPG conversion
Quoteby chance I have figured out my EML problem, it is due to the gas conversion, I have ran now 500 miles purely on gas so the EM has lowered the oxygen sensor reading, therfore when running on the expensive stuff my car complains (and it's not the only one  Grin)
That figures. The petrol ECU doesn't know it's not providing the fuel. Over time it will adapt the fuel map based on sensor readings and its' adjustments may evenually hit the limit because it's not actually controlling the fuelling. Does the LPG system take an input from the Lambda sensor or the fuel injector outputs on the petrol ECU or does it just use a fixed (open loop) mixture?
Another way of clearing it might be to disconnect the battery for a while (or just disconnect the petrol ECU). It depends on the type of non volatile memory used by the ECU but this could well clear the correction values and restore it to defaults.
lukie
as far as I know,  a single point takes a feed from the lambda sensor to monitor it's feed, it's a little strange, I start first thing in morning and EML is on, flick to gas it goes out, give it 5 mins switch to petrol and it stays out..... strange little thing, but hey saves me money on running cost's lol
Quoteas far as I know,  a single point takes a feed from the lambda sensor to monitor it's feed, it's a little strange
It could be that the strategy for Lambda control is slightly different between the gas system and the petrol system, i.e. it operates over a slightly different load / rev range. This might result in a small part of the fuel map where the petrol ecu thinks it's in closed loop but the gas ecu is not, therefore the corrections for that part of the map go out of range.
It's not a problem except that it might run a bit ropey when you switch back to petrol after using gas for a while but the ECU should re-learn the petrol settings pretty quick.
It might be worth taking it to an LPG specialist. The gas system probably creates a "false" Lambda signal for the petrol ECU when running on gas to keep it happy. Maybe the gas ECU settings can be tweaked to stop it. Then again, the petrol ECU probably won't go into closed loop until it's fully warmed up so why it complains at start-up I'm not sure.
