Author Topic: My Price list  (Read 2115 times)
My Price list
« on: 16 February 2007, 10:43:51 »
All prices here do not include PnP
V6 Bits:
Pair of cylinder heads with Cams £100
Pair of catalytic converters, good condition and low emissions £75
Gearbox selector switch £30 (STE)
Exhaust manifolds £10 each
ECU, Key chip and reciever £30
Alternator £15
Radiator £10
VERY GOOD RAD, all packaged up, never used: £20
Air con compressor£45
Dashboard (without MID) £15
Inlet manifold £10
Plenum £15
Throttle Bodies £10
Idle Control Valve £7
Door locks, x 3 £5 each (One free to Jaime)
Sunroof control with bugeye light etc £10
Headlight switch £5
Aux belt tensioner (bobo) £10
Water pump that's only covered 7000 miles £5
Cam pulleys x 4 = £5
Window motors x 4, £10 each, £40 total
Sunroof motor = £15
ABS/TC Ecu = £30
DIS pack = £25
Glove box with working catch £10
Working EGR Valve £10
ABS sensors £5 each
Genuine Crank sensor, only 4 months or so old, covered 7000 miles - £20
Cam sensor £10
Header tank with coolant level sensor £7
Rear light clusters £5 each
Headlights, £10 a side (not projector and would require a bit of a clean)
Relays, assorted, £1 each
Rocker covers: £15 the set
Wing mirrors, blue + electric £8 each
Bonnet struts: £10
Various other sensors £5
2.0 Bits
Crank sensor £8
Cam sensor £7
Aircon compressor and condensor, working £50
DIS Pack, x 2 £15 each
Inlet manifold + injector rail £7
Rocker cover £ 10
Catalytic converter £30
+ many other bits
If I can flog that lot, That's £800 - enough to buy a nice Elite :)
Martin_1962
Re: My Price list
« Reply #1 on: 16 February 2007, 12:02:15 »
I'd keep the 2.0 cam & crank sensors back if I were you, along with the AFM
JesterRT
  • Stafford
Re: My Price list
« Reply #2 on: 16 February 2007, 12:33:59 »
If either of the Air Con Compressor's can be transplanted onto the BMW 2.5TD engine then I'd be interested!
Anyone know if they are interchangeable? :-/
paulr
  • Frodsham
Re: My Price list
« Reply #3 on: 25 February 2007, 02:41:13 »
hi do you still have the ABS/TC Ecu @ £30 and is it the same as this one http://i110.photobucket.com/albums/n81/omegaforum/abs1.jpg if so and it works I will have it please. My cars an omega 2.5 v6 cdx year 2000, it will fit that wont it
« Last Edit: 25 February 2007, 02:42:34 by paulr »
Re: My Price list
« Reply #4 on: 25 February 2007, 03:01:45 »
No, that will be a later ECU than the cars JamesV6CDX is breaking....
