Author Topic: Top Guys At The 4 Pot Cam Party  (Read 1733 times)
Craig_R
  • Watford
« on: 24 February 2007, 22:13:29 »
Just want to post about how nice it was to see and say Hi to the people at Tunnies Cam Party
Everyone was Great, picked up a few great tips.
James his Mate were Work Horse's on the Cam belts 4 Pot & V6
Thanks Taxi Driver for Having alook for the Codes and Plugging in your tech2 to my Megga.
Sorry I had to Run When I did and did not make it over to the V6 Party, Had a Great Time   :y
Craig
« Last Edit: 24 February 2007, 22:14:13 by CraigR »
Mod's
[To be Fitted]Reverse Sensors
Taxi_Driver
Re: Top Guys At The 4 Pot Cam Party
« Reply #1 on: 24 February 2007, 22:54:46 »
Craig
Cheapo tech2  ;)
iirc it came up with lambda sensor fault.....we had a look and could see only one lambda sensor on the 2.0.....is this correct? coz ive 2 on my 2.2?... :-/
Also just remembered....plugged it into Tunnies 2.2....apart from wierd code from throttle position sensor.....it also came up up with lambda sensor 2 faulty  :-/
Martin_1962
« Reply #2 on: 24 February 2007, 23:23:19 »
1 sensor on 2.0
Craig_R
  • Watford
« Reply #3 on: 25 February 2007, 22:11:46 »
Yep That's all I found today when I had it Jacked Up one Four Lead Lambda
Checked out the Cables As The Boy Told Me to do and all the Cables Seemed fine,
Did Find a Cable Spliced in to one of the cables to the Lambds Sensor But Found Out
This was to do with My LPG as the cable ran to my LPG ECU which I guess makes sence
as the LPG ECU would need to know the reading from the Lambda sensor.
But Looks Like Ill be needing a new Lambda Sensor.
Taxi Driver Can you remember the Pins I needed to check it out ?
Craig
Mod's
