Pages: 1 ... 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 ... 29   Go Down
Author Topic: V6 Cambelt party - Brackley  (Read 78070 times)
Admin
Re: V6 Cambelt party - Brackley
« Reply #135 on: 20 February 2007, 22:10:00 »
I trust you mean locking kits as I really would not want a "borrowed kit" :)
The Administrator.
sounds2k
  • Queenborough, Kent
    • Saabs and a Jag XFR
« Reply #136 on: 20 February 2007, 22:10:32 »
What the hell for....nothing from it fits a 2/3 engine.....
the plastic box??  ;D
« Last Edit: 20 February 2007, 22:15:35 by Mark »
Bo Bo
  • Coventry
« Reply #137 on: 20 February 2007, 22:13:38 »
Who's in charge of taking pictures then?
Looking at that workstack, we won't have time for pictures  8-)
Me ;)
I knew you were coming for a reason ;) :y
After all, we ain't letting you loose on someone's car - you may shear a bolt on the waterpump ::)
 :-[It was my car though
Only because we didn't let you touch any others....  ;)
I need back up here Bo Bo , where are you :D watching Life on Mars I suppose ::)
Yep.....
« Reply #138 on: 20 February 2007, 22:16:41 »
What the hell for....nothing from it fits a 2[size=14]/[/size]3 engine.....
We have a V6 at the 2.2 party since the V6 location is full!!!
Nothing wrong with the 4pots, I get 10mpg better at 80+ in the 2.2 compared to the Senator!
Bo Bo
  • Coventry
« Reply #139 on: 20 February 2007, 22:20:06 »
Me ;)
I'd never have got those bolts back in the aux belt tensioner  :y
« Last Edit: 20 February 2007, 22:20:35 by paulmccristall »
sounds2k
« Reply #140 on: 20 February 2007, 22:20:51 »
.... apparently if you take your foot off the accelerator in the sennie the MPG improves  ;)
I'll be bringing (but not using) my locking kit & 30mm spanner so they can be used at either location (or both) ...
« Reply #141 on: 20 February 2007, 22:23:56 »
I managed to squeeze 37 mpg from the Senator on the run back to uni, but that was doing 65 mph all the way back!
I can get 36mpg doing 85mph with 3 people in the car in the 2.2 on a motorway run!
That extra kit will come in handy! Thanks!  :y
« Last Edit: 20 February 2007, 22:24:57 by tunnie »
Timbuk
  • Telford
  • owned a Datsun 120y once!
« Reply #142 on: 20 February 2007, 22:24:42 »
Me ;)
See Mr Jaime, i can do some things ::)
AndersH
  • Poole
« Reply #143 on: 20 February 2007, 23:02:02 »
My stuff arrived today from Autovaux, wondering if I've got the right thing though as Tunnie said his was GM and mine doesn't look like it is - I know it's a different part as we have different engines but mine seems to made by SKF - is this right?
sounds2k
« Reply #144 on: 20 February 2007, 23:06:17 »
I seem to remember SKF make the bearings used in the tensioners ... what does it say on the belt itself - contitech?
« Reply #145 on: 20 February 2007, 23:06:36 »
Mine should be GM its back home so not checked yet, they better have sent me the right kit!
When I rang up they said it would be a genuine GM kit sent...
AndersH
  • Poole
« Reply #146 on: 20 February 2007, 23:12:24 »
It says Gates PowerGrip....   :-/
sounds2k
« Reply #147 on: 20 February 2007, 23:16:30 »
... not a problem. Mine was a Gates "powergrip" kit bought from a local motor factors - cost me about £100  :o
but Gates are apparently one of (if not the) best ... have done 6k since it was fitted ...
AndersH
  • Poole
« Reply #148 on: 20 February 2007, 23:30:51 »
Ah good, that's ok then!  :D
« Reply #149 on: 21 February 2007, 08:10:33 »
A Gates belt and SKF bearings are absolutely fine :y
Pages: 1 ... 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 ... 29   Go Up
