Pages: 1 2 [3] 4 5 6 7 8 9 10 ... 29   Go Down
Author Topic: V6 Cambelt party - Brackley  (Read 78098 times)
Re: V6 Cambelt party - Brackley
« Reply #30 on: 19 February 2007, 19:53:35 »
I have a cambelt that needs doing, can I come?!
Blimey, thats a fair old trek ;)
What needs doing?
Just a quick run around the block in an Omega!  :D
AndersH
  • Poole
« Reply #31 on: 19 February 2007, 20:04:03 »
What needs doing?
Exactly! any old excuse to bomb up the motorway in the Omega! Also, I wouldn't mind someone else driving mine or sitting in someone else's. People always talk about how quiet their Omegas are - mine certainly isn't to me!
Anyway I've ordered a cambelt kit and water pump - I may even stretch to a gearbox upgrade if Tech2's making an appearance, sounds worth it reading the post about it.
« Reply #32 on: 19 February 2007, 20:09:54 »
So, currently we have the following experts lending a hand:
Marks_DTM_Calib
Laidback66
Me (expert in the loose sense ;))
And the following coming:
MaxV6 (confirmed) - Cambelt, waterpump, handbrake, HID fix - Parts, I will get
Theolodian (probable) - HID fix - Parts, N/A
Manbafia (Confirmed) - Cambelt, waterpump - Parts, member will get
BazMV6 (unknown) - a check over - Parts, N/A
Kevin Wood (unknown) - Cruise enable - Parts, member will get stalk.
Those above please confirm if you're coming, and confirm the list above is correct please.
« Last Edit: 19 February 2007, 20:42:31 by TheBoy »
Bo Bo
  • Coventry
« Reply #33 on: 19 February 2007, 20:45:57 »
If I don't hear from Elite Pete soon, I'll be able to pop round too.........
« Reply #34 on: 19 February 2007, 20:55:37 »
Tech2 will be available, for pricelist, see my post at top of every section...
OK. That's great. I'll be there.
I also would like to install cruise at some point so would like someone to show me roughly where everything goes!
Well, I've got the stalk on order so if that's arrived by the weekend I'll bring it along and we can see if we can muddle our way through it I guess!
Cheers,
« Reply #35 on: 19 February 2007, 21:01:45 »
Cheers,
Yup, no problem. Just ensure the stalk is the 4 wire variant (the common one), not the 2 wire one as used on 2.5TD Omegas...
« Reply #36 on: 19 February 2007, 21:02:30 »
Marks_DTM_Calib
Laidback66
Kevin Wood (Confirmed) - Cruise enable - Parts, member will get stalk.
« Reply #37 on: 19 February 2007, 21:05:03 »
Cheers,
Cruise stalk on facelift Omega's are a piece of piss, really are!
5 min job, 2 mins on tech2. Done. Best mod I ever had done on mine, and it was a £300 factory fit option!  :o
« Reply #38 on: 19 February 2007, 21:11:06 »
Cheers,
Fitting the stalk is easy - 5 screws. Enabling it in the ECU is a little more challenging, unless you have a tech2 ;)
« Reply #39 on: 19 February 2007, 21:11:49 »
Cheers,
Is it an auto or manual?
MikeDundee
  • Costa Del Peckham
« Reply #40 on: 19 February 2007, 21:15:17 »
Cheers,
Any camping facilities in NN14?, I ma an expert lager drinker, malt whiskey Oh and BBQ professional :y
MaxV6
  • Oxford UK
    • 2.2SportPremium Jag est
    • Work related forums....
« Reply #41 on: 19 February 2007, 21:31:51 »
Cheers,
if it hasn't arrived, I have an old spare used one somewhere or other, let me know before too late on friday eh?  you're welcome to it...
Failing that i have a fairly new one on the Sintra, which isn't in use right now...  I could whip that off and you can simply swap it out for your shiny new one when it does finally arrive.. and return my one from the Sintra (yes they are the same part....   I discovered this... when I had my brake light switch replaced last year, they fitted the wrong one and my cruise stopped working....  after being charged a couple of hours for "diagnostic investigation" without remedying the sudden failure of cruise control after the service , I swapped the stalk out....    then the switch ( with contortionist assistance from a friend ) , needless to say the general manager got a snotty letter and I won;t use that garage again....
That way you'll at least be able to ,make the most of the weekend's events...
Max
SteveD
  • Blackpool (no casino)
« Reply #42 on: 19 February 2007, 21:40:34 »
You can list me as a maybe. I can't confirm until Friday because of kids football comittments. Don't need anything doing but would like to come say hello and maybe get gearbox upgrade if time permits.  :)
« Reply #43 on: 19 February 2007, 21:42:03 »
Marks_DTM_Calib
Laidback66
SteveD (Possible) - Autobox s/w update - Parts, N/A
theolodian
  • I need a new avatar.
« Reply #44 on: 19 February 2007, 21:51:40 »
Yeah put me down for confirmed.  I'm also interested in a g/b update, etc. but not anything that requires parts.  When is this all kicking off?
Pages: 1 2 [3] 4 5 6 7 8 9 10 ... 29   Go Up
