Pages: [1] 2 3  All   Go Down
Author Topic: Free sat + Sky Plus advice  (Read 2853 times)
HolyCount
« on: 25 October 2009, 13:00:27 »
I currently have Sky + and an HD ready TV --- don't want to fork out £10 extra per month for the few channels Sky offer in "quasi HD", but, just for the hell of it, was thinking about installing Freesat alongside the sky box and using that for the "HD-ish" channels they broadcast.
Now .... can I piggy back off the same dish --- or do I need a seperate dish ?  And, if I can use the same dish, how would I connect it all up ? (in words of one syllable, please ).
Plomien
  • Swansea
    • Landrover Freelander TD4
Re: Free sat + Sky Plus advice
« Reply #1 on: 25 October 2009, 13:20:59 »
you can piggy back off the same dish just a case of splitting the cable you can buy the kits in maplin :y
« Reply #2 on: 25 October 2009, 13:47:30 »
You would need a new LNB with multiple channels to do it properly because the set top box can comand the LNB to change channel, which would scupper any boxes slaved from it... Assuming you need to use the skybox and freesat at the same time.
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #3 on: 25 October 2009, 14:11:27 »
As Kevin say's, think Sky+ already uses a 2 port LNB, so your probably going to need a Quad one.
« Reply #4 on: 25 October 2009, 14:13:32 »
LNB thats the device that sits facing the dish, and focuses the signal from the satellite?
« Reply #5 on: 25 October 2009, 14:24:58 »
I've fitted a quad LNB, it was easy enough to do and quite cheap off Ebay, its been up for about a year and i've not had any problems ;)
zirk
  • Epping Forest
« Reply #6 on: 25 October 2009, 14:26:28 »
Correct, and also reduces the Sat frequency to a lower IF frequency for the reciever to play with.  :y
« Reply #7 on: 25 October 2009, 14:34:39 »
Yes, but it does much more than that. The signal is in the K-u band (10GHz) which would be impractical to pipe down to the set top box so the LNB amplifies it and drops it down to an intermediate frequency. Frequency and pollarisation are normally switcheable by the set top box, hence the need for an independant LNB channel for each tuner.
HolyCount
« Reply #8 on: 25 October 2009, 14:41:37 »
So --- I need to replace the dual LNB with a quad, run an extra  co-ax lead to the freesat and the two current leads to the sky box ???
« Last Edit: 25 October 2009, 14:52:38 by HolyCount »
zirk
  • Epping Forest
« Reply #9 on: 25 October 2009, 14:45:03 »
You forgot to mention the other bit Kevin, that the LNB is powered from the Reciever up the coax, so again two recievers feeding one LNB is a no, no.
« Reply #10 on: 25 October 2009, 14:48:49 »
True. You'd need a splitter that handles the DC path correctly too. :y
« Reply #11 on: 25 October 2009, 15:05:16 »
...interesting point but does running two Sky receivers - as in 1 HD box and 1 Sky+ box for example - off 1 quad output LNB not suggest that this factor has been taken care off?
zirk
  • Epping Forest
« Reply #12 on: 25 October 2009, 15:38:49 »
Not played with Digital much lately, but if it's an independent Quad LNB then should be fine for Multi Recievers.
Forgot to mention, I get 33% discount of my Local Trade supplier (Not Boxes or TV's) if anyone needs any bits.
Chris  :y
Martin_1962
« Reply #13 on: 25 October 2009, 15:41:01 »
Quad LNB two for Sky and two for Freesat
There is only 1 decent Freesat receiver and it is much better than the Sky PVR
Humax HDR :y :y
pscocoa
  • Sandhurst Berkshire
    • Volvo V90 D5 & Grandland
« Reply #14 on: 25 October 2009, 16:26:11 »
Just to give a slightly different option - I ran a FreeSat HD Box and a Sky Digibox (without subscription) off a single LNB with a Maplins splitter (reverse wired 1input to 2 outputs) - this was a mechaincal switch between the two and worked fine.
I recently moved to Sky HD and now paying load of money again.
Pages: [1] 2 3  All   Go Up
Page created in 0.035 seconds with 20 queries.
