Pages: 1 2 3 4 [5]  All   Go Down
Author Topic: help with tools, electrical.  (Read 6131 times)
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
Re: help with tools, electrical.
« Reply #60 on: 29 October 2009, 14:49:54 »
check the conections at the back of the lighting plug and the socket that it is pluged into  :y
if your getting a volts drop then my money would be on a bad neutral somewhere  :y
KillerWatt
« Reply #61 on: 29 October 2009, 20:36:09 »
a ring main is where your live / neutral / earth starts at the fuse board and goes to the 1st socket.............. then from the 1st to the 2nd and so on till you reach your last socket then you go back to the fuse  :y
a spur is where you take a 3rd wire ( live / neutral / earth and take it to another socket ( a max of 4 sockets can be spured off a ring )   :y
a radial is where you come out of the fuseboard ( like in a ring ) and go upto a max of 4 sockets then stop !   these are normally on a 15 or 20amp fuse  :y
You really need to go slightly more in depth if you are going to start explaining what's what with the juice.
A very high percentage here don't have a clue, and your "generalisation" isn't going to help IMO.
« Reply #62 on: 29 October 2009, 20:54:14 »
Hmmm, better have a look behind there then, drag the dishwasher out and get behind the units. :-(
KillerWatt
« Reply #63 on: 29 October 2009, 21:30:50 »
You are less than 20 miles from me Chris.
My working hours are as follows:
Mon - Thur 9am - 3pm
Fri - 9am - 12 noon
Now ignoring the fact that I work according to pub opening hours, if you are seriously that worried about the lx in your home then I am more than happy to give it a full inspect/test while you ply me with lager for the duration (no more than 2 hours).
Full report at the end, and the only charge is a drink if you are REALLY that worried.
« Reply #64 on: 30 October 2009, 01:26:19 »
Fri - 9am - 12 noon
Not worried at all in all honesty, but thanks very much for the offer :-). I just dont like not understanding these things. In the course of this thread its clear serious training, or at least a heavy interest, is needed to understand it fully, or to a decent level at least.
Its not something i'm going to pick up in 5 mins. But put something in front of me and i'll usually find whats wrong. I just wont know the correct terminology or the mathematics and symbols.....
Like tiger said earlier about a spur, i knew what it was when he described it, i just didnt know what it was called before hand.
I think maybe i need a little project and learn hands on.... hang on, i'll see if i can find it. :-)
« Last Edit: 30 October 2009, 01:31:22 by chrisgixer »
« Reply #65 on: 30 October 2009, 02:22:11 »
« Reply #66 on: 30 October 2009, 09:28:49 »
found it, click the link and then click   DVB-t Astra G CID
http://translate.google.co.uk/translate?prev=hp&hl=en&js=y&u=http%3A%2F%2Fwww.migrosser.de.vu%2F&sl=de&tl=en&history_state0=&swap=1
 :y ::)
May I be so bold as to suggest starting with one described in English?  ;)
« Reply #67 on: 30 October 2009, 14:12:28 »
 :y ::)
yeah, slight problem admitedly... :(
diags alone are no good i take it?
 he supplys the parts, as confirmed by email....as far as i can tell anyway  ;D
« Reply #68 on: 30 October 2009, 14:56:39 »
No, I can see what he's getting at. Looks like a circuit that just switches in a separate RGB feed to the CID, with a sync separator.
« Reply #69 on: 30 October 2009, 15:14:02 »
yes, from what i can make out/understand....
he also lists an aux in for mp3 player as a mod, and seems it can be done without opening the unit, or something like, and there by not affecting warranty,not that that matters now, but may point to something simpler?
 shame the google translation is not a bit more accurate
« Reply #70 on: 30 October 2009, 15:21:42 »
yeah listed under    "Display + Line IN"  :)
« Reply #71 on: 30 October 2009, 15:30:45 »
Hmm. His line-in looks like a bit of a bodge. :-/
« Reply #72 on: 30 October 2009, 23:20:25 »
Oh, how do you mean?  :-?
Pages: 1 2 3 4 [5]  All   Go Up
