Author Topic: windows 7  (Read 6466 times)
Plomien
  • Swansea
    • Landrover Freelander TD4
Re: windows 7
« Reply #15 on: 24 October 2009, 22:08:27 »
Just been helping my dad install his ADSL connection on it but no joy as PIPEX don't support USB modems on win 7 so at last he will ditch them and get free internet with sky with a wireless connection!!
so you mean win 7 is not ok..  :-? :-?
Its fine other than that just hasn't been fully tested as no net connection at present :y
I was using a beta version and found it really good and will be upgrading my xp machine once funds allow
KillerWatt
Re: windows 7
« Reply #16 on: 25 October 2009, 08:38:42 »
What do Pipex have to do with that?
Get yourself an ADSL wireless router (£30-£40) plug that in, setup the configuration in the web interface, job done!
They supplied the original modem and aren't offering support on win 7 for them but still support xp and vista. I am alright though as I am on cable. (but have been nagging my dad to get a adsl wireless for ages) :y
I didn't think anybody used those crappy USB modems any more, but if you had it working under Vista then there is no reason that it should not work under 7 using the Vista driver.
Re: windows 7
« Reply #17 on: 25 October 2009, 08:43:09 »
After all... Windows 7 is actually the re-modelled Vista and how it should have come out if they'd done the research properly. Vista drivers are supposed to work with 7 with no issues at all.
KillerWatt
Re: windows 7
« Reply #18 on: 25 October 2009, 08:55:22 »
Absolutely.
Vista was simply "cobbled" together and thrown out the door in order to meet a timeframe.
Sadly, in order to get it out in time, they sent it out very broken.
Agreed.
I've put 7 on two machines here this week (laptop & desktop), and they were more than happy to accept the Vista drivers for everything.
« Last Edit: 25 October 2009, 08:56:27 by KillerWatt »
jimmas
  • stevenage, herts
Re: windows 7
« Reply #19 on: 25 October 2009, 14:32:16 »
thanks cem, works fine now all re-installed, very pleased so far  :y
pedroMV6
  • York
  • Der Metzgermeister
Re: windows 7
« Reply #20 on: 25 October 2009, 14:35:11 »
I know sod all about PC's, but this new one has Vista and the printer/scanner has issues with it. the printer works, but the scanner won't. ::) ::) ::)
I dunno if getting Windows 7 would sort that out?
Re: windows 7
« Reply #21 on: 25 October 2009, 16:14:21 »
good news  :y
KillerWatt
Re: windows 7
« Reply #22 on: 25 October 2009, 16:27:47 »
That is nothing more than a driver issue.
If the printer/scanner manufacturer doesn't offer Vista drivers (or if the XP driver fails to work), then that is down to the manufacturer of your hardware.
« Last Edit: 25 October 2009, 16:29:04 by KillerWatt »
ENFIELD_MV6
  • Enfield
  • previously from leicestershire
Re: windows 7
« Reply #23 on: 29 October 2009, 23:30:43 »
cool i think a new lappy with 7 will be with me in 10 days then lol 17" toshiba me thinks so i can see the forum bigger and better
Nice one, I like the Tosh lappy's I have had in the past, will be nice with a 17" screen.   :y :y
would have to waited 3 weeks for delivery for 17" so gone for a 15.6" versio with windows 7 will be with me in 5 days woo hoo
mathewst
  • Split, Croatia
    • v40
Re: windows 7
« Reply #24 on: 30 October 2009, 08:26:21 »
Don't use it but some other colleagues from IT are using it and they only have good opinions about it.
All of them agree that Vista was cr.. and this is great.
Re: windows 7
« Reply #25 on: 30 October 2009, 09:20:48 »
A few comments...
If you have used Vista, the chances are you will think Win7 is great - you've already had the pain of learning where stuff is, and hopefully cottoned on to the new way of working (ie, pressing Windows on keyboard and typing CV to update you cv document etc). You've already come across UAC, and hopefully understand its benefits, and also know you should NEVER disable it (if you do, your ego is bigger than you basic computer knowledge).
If you are coming from XP, having skipped Vista, then you've got a bit of learning to do - a lot of stuff is in different places, and it takes time to learn to automatically use the search box on the start menu.  You also need to learn that running as a computer Administrator does not necessarily run you as an admin - one of the best security thing MS has done to Windows, and one thing that catches a lot of XP'ers out.
IMHO, Windows 7 is an improvement on Vista, which itself was a massive improvement on XP (which was always rubbish due to the compromises to get the Win9x line into it (which is why W2K often multitasked so much better), SP2 improved the matter, but look at the uproar that caused as it broke poor apps/drivers).
If we had gone straight from XP to W7, I guess people would hate W7, due to the changes and to UAC. Also, the new driver architecture would mean all the drivers would be immature and not as abundent.
Windows 7 does have excellent driver support - in most cases, if there is no specific Windows 7 driver, a Vista one should suffice. That is not always 100% the case, as some driver manufacturers can't even get simple things right.  64bit still isn't 100% covered on drivers, despite Microsoft's insistance that any WHQL driver has to come in 32 and 64.  Older printers seem to be a common one.  I had a problem with USB - Serial adapters under Win7 64 (and Vista 64).
Lastly
NEVER EVER EVER upgrade an operating system. ALWAYS rebuild it from scratch.
Re: windows 7
« Reply #26 on: 30 October 2009, 09:22:03 »
Vista was a massive improvement (and a massive change) from XP.  Windows 7 is an evolution of Vista.
Re: windows 7
« Reply #27 on: 30 October 2009, 09:23:43 »
In fact it was possible that if Vista hadn't had the bad reputation given in the poor computer mags (who employ the journalists so useless that they can't get other journalist work), Windows 7 may have been called Vista R2 ;)
ENFIELD_MV6
  • Enfield
Re: windows 7
« Reply #28 on: 30 October 2009, 09:24:00 »
i got lost after the first line, i have no idea really bout vista, only use the laptop to surf the net, here, ebay and facebook and thats about it
Re: windows 7
« Reply #29 on: 30 October 2009, 09:38:18 »
If thats all - Internet Explorer is Internet Explorer, whether it be XP, Vista or W7 ;)
Obviously the more modern OSes give better user protection
