Author Topic: Martin  (Read 5707 times)
Re: Martin
« Reply #15 on: 12 March 2007, 21:52:52 »
BT Home hub - well if I had a hub hub I would need normal cables not cross over, it uses Linux.
Using most of my quota too :y
I'll check tomorrow, but I though Home Hub needed straight cables.  Its probably auto MDX, so either should work anyway...
Martin_1962
Re: Martin
« Reply #16 on: 12 March 2007, 22:44:38 »
Can't find the manual - I'll check tomorrow when I might find it.
I had a cross over lying around, which I used before I found the BT cable which is straight through - I think I'll change tomorrow night
Re: Martin
« Reply #17 on: 13 March 2007, 17:40:21 »
It won't affect the latency etc though.  Is it DNS slow to respond, or general high latency?
Martin_1962
Re: Martin
« Reply #18 on: 13 March 2007, 22:45:50 »
Dunno, I think it is easier to debug a large barcode generator which is perfect in the office but is slow in one factory, took 3 hours to debug.
Then had to fix someone elses C code - made a char 80 rather than 32
Re: Martin
« Reply #19 on: 14 March 2007, 20:16:35 »
Try different DNS servers to prove ;)
Martin_1962
Re: Martin
« Reply #20 on: 14 March 2007, 20:21:11 »
It is responsive today but I think they upgraded the local exchange
Re: Martin
« Reply #21 on: 14 March 2007, 20:33:46 »
Were VPs congested then?
