Author Topic: Re: Front wheel bearing change - all models  (Read 3472 times)
waspy
« Reply #15 on: 21 November 2009, 08:58:22 »
what happens between removing hub carrier bolts and fitting bearing as there no picture to explain....is there a special way to get old bearing off...got humming on front so think mine need doing.....
Err, you just replied to a thread started 2007  :o
He's new & he also has a question about a problem so what's the problem :-/
Mr Stud
  • somerset
« Reply #16 on: 21 November 2009, 09:02:24 »
Err,and....think mine needs replacing...found the guide before posting a new thread on how to change it :)...noticed picture missing in guide...need to know what missing....simples :)
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
« Reply #17 on: 21 November 2009, 09:03:43 »
after removing the caliper & disc & taking off the hub dust cap, undo the centre retaining hub nut & it should pull off. pressume your fitting new hub with bearing complete.
Mr Stud
  • somerset
« Reply #18 on: 21 November 2009, 09:09:51 »
do they only come complete or is the bearing seperate to the hub
The Red Baron
« Reply #19 on: 21 November 2009, 09:16:48 »
would imagine you could get the bearing on its own but i fitted hub complete. :y
