Author Topic: Fault Code Help Required  (Read 3322 times)
STMO999
Re: Fault Code Help Required
« Reply #15 on: 01 January 2010, 20:12:34 »
P1835....code reader knackered ;D
Pippin
  • Birmingham
    • Vauxhall Signum 1.9CDTi
« Reply #16 on: 01 January 2010, 21:15:43 »
That would just be my luck.....
RoSPA Gold Advanced Driver
Trade Card Holder
« Reply #17 on: 02 January 2010, 10:10:05 »
symptoms?
Pippin
  • Birmingham
« Reply #18 on: 02 January 2010, 18:57:30 »
No noticable symptoms, drives ok, seems to change gear ok, just get the P0304 code regularly but no actual hesitation or misfire... will be changing the DIS Pack on Tuesday just to try that.....
Checked the most obvious things like oil in plug wells and breathers...all fine..
« Last Edit: 02 January 2010, 18:58:42 by Pippin »
Trade Card Holder
« Reply #19 on: 02 January 2010, 19:03:00 »
Sure not a P0340 - that often triggers odd gearbox codes
Pippin
  • Birmingham
« Reply #20 on: 02 January 2010, 19:51:20 »
No, definately a P0304 cylinder 4 misfire detected...
Trade Card Holder
« Reply #21 on: 02 January 2010, 20:24:15 »
SWMBO's Astra G went through a period of 0300 & 0302 I changed the plugs which put the light out
............. for a week!  :(
Changed the coil pack for a pattern part which put the light out
........ for a couple of days.  :'(
I put some Redex through the inlet manifold & the rest through the tank which seemed to do the trick over the next few hundred miles.  ;)  :y
Pippin
  • Birmingham
« Reply #22 on: 03 January 2010, 19:54:55 »
At first i wondered if it had got anything to do with the LPG so i ran it on Petrol for a week and the P0304 still randomly came up.....
Not sure on the injector cleaner, would it cause any issues with the LPG (I know its probably a silly question to ask but i'm not brilliant when it comes to cars)...
Trade Card Holder
Pippin
  • Birmingham
« Reply #23 on: 04 January 2010, 21:02:27 »
I'm changing the DIS pac tomorrow, do you think it would be worth clearing the codes after i've done that to see if they come back again? :y
Trade Card Holder
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« Reply #24 on: 05 January 2010, 06:42:53 »
Yes.
I like red cars
Pippin
  • Birmingham
« Reply #25 on: 05 January 2010, 13:56:39 »
Well the weather brought the change of DIS pack to a halt, couldn't get there to collect it so will have to wait till weather improves a little...
But as soon as i have changed it i will clear all the fault codes (After keeping a note of them) and see what happens... :y
Trade Card Holder
