Author Topic: suns radiation will bugger your sat nav, they say  (Read 1798 times)
Tony H
  • liverpool
  • Black Elites are luurvley
Re: suns radiation will bugger your sat nav, they say
« Reply #15 on: 11 February 2010, 20:20:45 »
http://www.telegraph.co.uk/science/science-news/7204617/Stronger-radiation-from-the-Sun-will-cause-sat-navs-to-fail-scientists-warn.html
GOOD. Hope it explodes the stupid rather' things. >:(
;D ;D ;D ;D
Well, hopefully the planes wont explode or crash or land short of the runway. I live on the approach flight path to Heathrow... ;D
Planes use ILS to help them land in reduced visability.  Nowt to do with GPS :y
Glad about that the GPS on my boat will often tell me I am at an altitude of thirty feet plus  :o.
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« Reply #16 on: 11 February 2010, 20:29:47 »
;D ;D ;D ;D
Atlantic swell?  ::) ::) ;D
Tony H
  • liverpool
« Reply #17 on: 11 February 2010, 22:42:54 »
;D ;D ;D ;D
Don't think so. It tells me that even when it's parked up on it's trailer  :D
« Reply #19 on: 11 February 2010, 23:03:59 »
Solar flux peaks every 11-13 years and hasn't ever caused any serious issues other than a cr@p TV picture. Then again, maybe the public had some common sense left last time. ::)
<geek mode> As a radio amateur, I'm looking forward to it. </geek mode>
Arh the Skip :y I remember this from my CB days, chatting to some guy fishing just off the coast of Australia :)
I was armed with a Multi-Mode II, a 500 watt buner & a Directional Beam. My parents house looked like a Porcupine & so did my car ;D ;D
Fond memories :) :)
 :o :o 500W!  Did you have a license for that  ::) ::)
When I was into CB radio (AM) there were no licenses..... :D :D :D
Still have one in the garage somewhere.... :-X
« Reply #20 on: 11 February 2010, 23:26:43 »
"next generation" enhanced landing systems will use GPS inputs to a large degree
LAAS  : http://en.wikipedia.org/wiki/Local_Area_Augmentation_System
GNSSA  : http://en.wikipedia.org/wiki/Ground_Based_Augmentation_System#Ground_Based_Augmentation_System
The whole idea is to reduce the time/distance between each aircraft on the approach, as this is the major bottleneck. On an ILS a minimum of 5 miles has to be maintained between aircraft to avoid the "front" one affecting the signal to the one behind.
there is also a major cost saving .. at present each runway needs an ILS at each end ... so O'hare needs 12 ILS installations ...  :(
With LAAS one install does the whole local area ...   :)
« Last Edit: 11 February 2010, 23:28:22 by entwood »
Banjax
  • Perth
« Reply #21 on: 12 February 2010, 06:38:06 »
What a very poorly worded and miss-informed article.
Experts said the bursts of radiation caused by the flares interfere with signals from satellites orbiting the earth, causing receivers to fail and lose track of their position
They wont fail at all, they may loose reception from 1 or more satellites but, thats it.
It is feared this will cause satnav receivers to be blinded for minutes at a time and could result in drivers becoming lost or involved in accidents.
Jesus, are people THAT stupid!
Figures show that last year satellite navigation systems were blamed for causing around 300,000 people to crash in Britain.
If the figures are true, then clearly they are!
so about 3 times more than the total number of road traffic accidents then? seems a bit sus if you're asking  :o
papers eh? what are they like  ;D
