Pages: 1 [2] 3  All   Go Down
Author Topic: Project B Aquired!  (Read 12889 times)
Salty
  • Fleetwood
Re: Project B Aquired!
« Reply #15 on: 17 August 2006, 20:36:35 »
yes no longer just a 'full member'  ;D
Radio is a bit of PITA.... but as McB said not to bother!!!, i might just rip one out of the scrappy and shove it in the hole and say it does't work!
Tomorrows plan, give it a damn good clean. (after i have been to the scrappy)
People who buy cars in that sort of price bracket aren't generally looking for the perfect motor so the radio probably won't bother them too much.
« Reply #16 on: 17 August 2006, 20:38:55 »
Agreed. Main sticking point with a sale at the moment is the leccy seats don't work, and won't go backwards or forwards (no manual bar), so the buyer needs to be average height of about 5ft8  ;D
« Reply #17 on: 17 August 2006, 20:43:53 »
Don't they have a manual mech for the forwards and backwards bit?  Leccy seats are diagnosable via tech2, but I'd check it the old way - with a meter...
Salty
  • Fleetwood
« Reply #18 on: 17 August 2006, 20:44:29 »
Ahh your going for the niche market then ;D ;D
« Last Edit: 17 August 2006, 20:44:43 by salty »
Salty
  • Fleetwood
« Reply #19 on: 17 August 2006, 20:45:44 »
Yep I got a short dog legged steel bar with mine for manual adjustment in case of failure, like a toy cranking handle
« Last Edit: 17 August 2006, 20:46:10 by salty »
« Reply #20 on: 17 August 2006, 20:46:57 »
Could't see anything, not had a real chance to get a good look yet.
You mean check the fuses with a meter?
Salty
  • Fleetwood
« Reply #21 on: 17 August 2006, 20:48:37 »
Check the power at the seat connections
« Reply #22 on: 17 August 2006, 20:51:45 »
Be careful playing with the seat connector whilst ignition on as the SRS could fire....
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
« Reply #23 on: 17 August 2006, 20:54:33 »
i would disconect the battery before doing so - may be more time consuming but saves deployment  ;)
mr des
  • limerick, ireland
  • Doh
« Reply #24 on: 17 August 2006, 21:16:04 »
but how do you know if there is power then? well two ways continuity with positive disconected terminal and positive on connector or with batt connected use probes which pierce the insulation which will seal up when your done or option three disconect batt and run 12v to the seat motor direct but fit an approiate fuse in line ie two leads, one for neg one for +ve. big croc clip on one end little on other, in line fuse holder on +ve then connect motor direct to batt
i want to shine in the eye of orion but i drove my sole through the black hole
« Reply #25 on: 17 August 2006, 21:19:32 »
Point taken... speaking of the battery it looks like it should be in a Corsa, not a 3.0 V6 megga its tiny!! - Seams to start ok though.
Just leave it for a few mins after disconnecting the battery??
I think most of the connections are good, i did't notice any loose wires, but will investigate tomorrow
« Reply #26 on: 17 August 2006, 21:23:13 »
Talking of batteries, hows the facelift?
« Reply #27 on: 17 August 2006, 21:41:34 »
Good acually, thanks for the charger.
Left it on all night, was putting in slightly under 2 amps by the morning.
Started fine, drove to Bicester North to take the train to London... picked up the car at around 8pm.. started fine..  :)
« Reply #28 on: 17 August 2006, 21:43:02 »
Thats good news, seems like the battery may have survived your bongo bongo music  ;)
« Reply #29 on: 17 August 2006, 21:46:11 »
 ;D ;D
Had a bit of AC/DC - Thunderstruck on the way back from the station... :)
The ICE in my facelift is a tad better than Project B
Pages: 1 [2] 3  All   Go Up
