Pages: 1 2 3 4 [5] 6 7 8   Go Down
Author Topic: Usual cambelt arguement  (Read 13480 times)
STMO999
Re: Usual cambelt arguement
« Reply #60 on: 03 September 2009, 21:27:27 »
That's two of my 'ex' posts been resurrected. Gives me the willies I tell you. :o
robbo299
  • luton, beds
« Reply #61 on: 03 September 2009, 21:30:14 »
It took me a couple of mins reading it to realise ;D. A lot of members have asked in the past what the difference is in the different kits so i thought i would post the pics up :y
zYx
  • Kent
  • Member of Mayday
    • Black 3.2
    • Grischke Solutions
« Reply #62 on: 04 September 2009, 06:57:31 »
Thanks for your pics, now I can see the difference :)
« Reply #63 on: 04 September 2009, 08:01:10 »
I got caught out by this old thread as well :-[. If any body needs to know what the 3 kits look like for all V6 engines from 2.5 to 3.2 see pics below. The part numbers are SKF reference numbers NOT Vauxhall`s. :y
As you can see the rear tensioners are different in each kit. Hope this helps :y
Not quite right.
The only difference between the lower 2 kits is the back plates for the tensioner (note, the original one can be used). The picture makes the idler look diferent because one is up side down but, they are actualy the same part.
The top kit has a different lower idler (its not concentrenic so  not adjustable) but, the earlier adjustable one can be used and again, the tnsioner backng plate can be re-used,
gee-man
  • cambs
« Reply #64 on: 05 September 2009, 20:48:33 »
is 4 years or 40k for all, recommended best practice
Martin_1962
« Reply #65 on: 05 September 2009, 20:57:28 »
My lower idler is adjustable as was the one I took off
Aeroman
« Reply #66 on: 29 October 2009, 23:29:12 »
While on the subject of V6 cam belt kits, I have just done one on a 1999 Omega 2.5 using the SKF kit AS 920 1887. The tensioner backplate is 01.
The belt is a Powerdrive one but the white timing marks were wrong. The crank and pulleys 1 and 2 were OK but the marks for pulleys 3 and 4 were well out.
I checked and double checked that I hadn't done anything stupid but no, it was the markings.
Any one else had this ?
« Last Edit: 29 October 2009, 23:32:23 by Aeroman »
« Reply #67 on: 30 October 2009, 08:58:26 »
Not sure thats the right backplate, I would have thought that would be an EB. What was the old backplate?
« Reply #68 on: 30 October 2009, 09:23:13 »
I take it you are using a proper locking kit.
« Reply #69 on: 30 October 2009, 09:37:30 »
01 is correct for the later engines setup (with different oil pump).
EB is the earlier type
Aeroman
« Reply #70 on: 30 October 2009, 17:46:05 »
Just to confirm a few points:
The plate I removed was an 01 too.
Yes I used the locking kit.
The new belt was the same length and number of teeth as the old one.
The real giveaway was that the four cam marks on the belt were wrong. The distance between 1 and 2 was OK as was 3 and 4  but the two pairs of markings (that is between 2 and 3) were about 6 teeth too close together so they wouldn't all line up when threaded round the intermediate adjuster. (The adjuster only compensates for about 1 or 2 teeth).
The distance from the crank marking to the cam pulley 1 marking was correct.
Weird eh!!
« Last Edit: 30 October 2009, 17:46:31 by Aeroman »
zYx
  • Kent
  • Member of Mayday
    • Black 3.2
« Reply #71 on: 16 February 2010, 21:33:23 »
never mind
« Last Edit: 17 February 2010, 07:18:17 by zYx »
« Reply #72 on: 16 February 2010, 21:38:05 »
That scared me .. STMO as an ex-member .. then I saw the date of the posts !!!
Some dusting due on this thread methinks !!!
And doing the job without the correct locking kit is IMHO .. plain stupid  :(
Cable ties and bits of wire are NOT sufficient to do the job properly.
comes under the heading "bodged" IMHO .... sorry ...  :-/ :-/ :-/ :-/ :-/
« Last Edit: 16 February 2010, 21:40:53 by entwood »
waspy
« Reply #73 on: 16 February 2010, 21:39:31 »
10 out of 10 for improvisation :y :y :y :y
& 10 out of 10 for making me think i was seeing things ;D
STMO999
« Reply #74 on: 16 February 2010, 21:43:19 »
 :-* :-* :-* ;D
Pages: 1 2 3 4 [5] 6 7 8   Go Up
