Author Topic: to chip or not to chip  (Read 4248 times)
dcz
  • inverness
« on: 01 April 2007, 00:14:14 »
hi  new to all this so take it easy ?  i have a 96 omega 2.5td and have the chance to buy a chip on ebay for £60 ,  sounds okay , but is it easy to fit and what difference will it make fuel and power
amigov6
Re: to chip or not to chip
« Reply #1 on: 01 April 2007, 02:23:16 »
 :D Be carefull. i bought a little box for £13 that plugs into the iat sensor(fuctifino) that is supposed to kid your engine it's running cold all the time so pushes more fuel in. I was daft enough to buy it but not daft enough to try & fit it ::)
« Reply #2 on: 01 April 2007, 06:46:42 »
I would imagine all that is, is a resister between the Coolant temp sensor and the ECU...
It will make it run rich and use a lot more fuel. It will also up your emissions which could be tricky at MOT time
Steer clear IMO
Talk to Omegatoy, he has a chipped TD, but his is a proper chip...
Ronald_McBurger
« Reply #3 on: 01 April 2007, 08:44:41 »
There is a box you can get and I cannot remember the name, but seem to think dragon? Anyway, plugs in and can boost it up to about 200bhp.
Omegatoys TD goes like a bat out of hell. It is a proper chip and isn't cheap, but IS worth it.
« Reply #4 on: 01 April 2007, 08:49:15 »
200bhp from the tractor.. are you serious!!
What sort of MPG can you expect once chipped?
« Reply #5 on: 01 April 2007, 09:56:43 »
Being turbo'd its possible to get huge performance gains, yet keep economy for cruising around....   ....can make engine feel a bit peeky though.
Omegatoy will have the answers...
Omegatoy
  • UK
« Reply #6 on: 01 April 2007, 21:11:35 »
 ;D economy? only 29.9 mpg  ::)
but thats when towing nearly 2 tons of caravan around spain!!!  :y
 on n its own everyday use back on forward to work 45/46 normal driving can get it down to 36/37 when booting it everywhere tho!!!
« Reply #7 on: 01 April 2007, 21:55:37 »
James... yup around 200bhp and yes it goes like the clappers. Its like rocket out of the blocks.... next time your up this way i would be tempted to go ask very nicely for a little drive. It does open your eyes a bit....
Omegatoy
  • UK
« Reply #8 on: 01 April 2007, 22:05:44 »
Offered Jamie a drive in the estate but warned him it would make his car feel very lethargic and he sensibly declined to drive it!!!! ;D
« Reply #9 on: 01 April 2007, 22:08:29 »
Aye, want to get my tractor working properly so I can see what they are supposed to be like.  Then, I will see what is possible from then on....
Ronald_McBurger
« Reply #10 on: 01 April 2007, 22:15:15 »
I told you Jaime. Let me take that tractor off your hands and I'll sort it.
« Reply #11 on: 01 April 2007, 22:18:28 »
I am entirely undecided what to do. Get it sorted and flog it, or keep it and chip it.  The MV6 is staying, as I can't see the tractor ever replacing that....
Omegatoy
  • UK
« Reply #12 on: 01 April 2007, 22:19:17 »
It already goes better then when he got it!! with just a couple of little bits done to it, we had an immediate improvement in pick and engine response, needs a bit more  yet tho!!
Omegatoy
« Reply #13 on: 01 April 2007, 22:22:21 »
You know you want to keep it to tow my future projects  ;)
« Reply #14 on: 01 April 2007, 22:28:17 »
A) You're not allowed to tow
B) No shin breakers on my cars - people might think I like caravans  >:(
