Author Topic: Also taking a break...  (Read 2693 times)
Re: Also taking a break...
« Reply #15 on: 12 April 2010, 13:24:01 »
No worries Josh, I want to look at your MV6 this week  :)
The 406? I have finally done one job on it:
 - An oil and filter change - which took all of half hour.
Still need to do cambelt kit, water pump, aux belt, wishbones, rear wheel bearing, brake service all round....  ::)
« Reply #16 on: 12 April 2010, 13:26:25 »
172,000 miles, no cambelt history, and the oil change prior to mine, was over 20k ago..
Asking for trouble  ;D
joshwyatt
  • Oxford
« Reply #17 on: 12 April 2010, 13:30:41 »
Thanks James, whatever time is best for you will be fine with me  :y
 ;D what do they say about builders having houses that are falling down, and car mechanics with dodgy cars? When you do it for a living or part time you never want to do your own.
When I saw the 406, the N/S looked tidy  ;D
Forget about the engine, you don't need one...just take it everywhere on the back of a truck  ::)
« Reply #18 on: 12 April 2010, 13:32:53 »
That all sounds very sensible James and I am very pleased for you that your career is going in the right direction! 8-) 8-) :y :y :y :y :y
You have discovered what most of us do with age; you cannot burn the candle both ends as you do in your teens / early twenties, and also you have greater family responsibilities.  You have made a wise decision if I may say so ;) ;) ;)
One day I will ask you down though to do the infamous, never happening change of a cam belt with me!!! ::) ::) ;D ;D ;D ;)
All the very best James :-* :-* :-*
« Reply #19 on: 12 April 2010, 13:36:01 »
Is it anywhere near Due?  ;)
« Reply #20 on: 12 April 2010, 13:48:16 »
We were down to the last 8K miles on the CDX, but then it was written off!   My latest Elite has another 20K or two years to go at least, but I may very well do it next year James come what may! ::) ::) :D :D ;)
« Reply #21 on: 12 April 2010, 14:55:29 »
Good luck James..  :y
Rockhampton
  • Trecelyn, Gwent
  • Gone!
« Reply #22 on: 12 April 2010, 16:35:11 »
James, best of luck for the future, and thanks for the work you've done on my car, and your advice on several matters  :y
I have to say, I could never work out when you found time to sleep, as you always seem to be running about  :)
Hope everything works out for you  :y
Previous GM Models include '00 Omega 2.5 CD Auto, '06 Holden Commodore Executive 3.6 Auto, '99 Astra 1.8 CDX Auto, several Astra Diesels.
« Reply #23 on: 12 April 2010, 17:44:35 »
Good luck mate .. don't be a stranger ...  :y :y :y :y
charlie
  • sunderland
« Reply #24 on: 12 April 2010, 17:55:27 »
A well earned one aswell,James.THe bit that surpises me is you work aswell,where have you found the time to do both :y
« Reply #25 on: 12 April 2010, 20:05:24 »
Thanks Gents..
Just to clarify - I won't be a stranger on the forum so much, it's the mobile mechanics I will be really cutting down...  :y
« Reply #26 on: 12 April 2010, 20:59:29 »
Hope the career change works out James. You'll be around here enough but I'll certainly stop recommending you for routine stuff :y
