Author Topic: Plumbing help...  (Read 3249 times)
Markjay
  • London
Plumbing help...
« on: 14 April 2007, 20:45:55 »
Did some plumbing today, mainly removed the bent pipes under the sinks and gave them a good clean. I know, should have done the rusty PAS pipe (I bought the Hammerite for it), but I spent all of last weekend on the car so...  :(
After putting back all the various plastic pipes etc, one of them seem to have dampness around the seal when the water is running... no matter how many times I took it apart, aligned it,and retightened, it still gets damp. Since i don't have any experience with this sort of stuff, before I change all the rubber seals, is it one of those things that are normal and will resolve themselves (please say so...), or if it is wet it will always be wet unless I change the rubber seal....?
My alternative idea is to put some black Vx sealant on the thread, great RTV stuff...
Thank you in advance.
« Last Edit: 14 April 2007, 20:47:09 by markjay »
Alas, no more Omegas....
Re: Plumbing help...
« Reply #1 on: 14 April 2007, 20:48:21 »
Is it the dreaded plastic pipe and push fit connectors...
Chopsdad
  • Bouncy Castle in Carlisle
  • Keep it clean!
« Reply #2 on: 14 April 2007, 20:50:46 »
Or brass conex fittings?  Either way it won't resolve itself  :(
Markjay
  • London
« Reply #3 on: 14 April 2007, 20:54:03 »
It's damp in spot (1), in the gap that appears between the two large 'nuts' after the top one is tightened up wards, so i suspect rubber seal (1) to be the problem...  :(
« Reply #4 on: 14 April 2007, 20:55:41 »
Yup, seal.
Markjay
  • London
« Reply #5 on: 14 April 2007, 20:56:41 »
Yup, seal.
On a Saturday night....
Chopsdad
  • Keep it clean!
« Reply #6 on: 14 April 2007, 20:57:09 »
Best to wrap some PTFE around the threads first and see if that stops it.  If not I'd replace the connector/pipe rather that just the rubber, they're fairly cheap and then you can guarantee a good seal.
Markjay
  • London
« Reply #7 on: 14 April 2007, 20:57:28 »
Many thanks guys  :y
« Reply #8 on: 14 April 2007, 20:58:11 »
Yup, seal.
B&Q, Wicks etc are all open tomorrow. Unlike BMW garages  >:(
Chopsdad
  • Keep it clean!
« Reply #9 on: 14 April 2007, 21:01:04 »
Yup, seal.
If you go to one of the above make sure you take the pipe with you.  Unfortunately they like to stock new stupid size connectors that wont fit existing plumbing.  You may have to wait until you can get to Plumb Centre etc.  Hopefully, with that U bend being a common item it'll fit ok.  :-/
benjamind
  • Manchester
« Reply #10 on: 14 April 2007, 21:46:31 »
hi mate just take the rubber washer off on arrow 1 and wrap ptfe in its place to form as new washer on arrow 2 undo connection and wrap ptfe around the washer ifdone right this will solve all your probelems       well plumbing at least ;D any problems please email me at magicalplumbing@aol,com
Taxi_Driver
« Reply #11 on: 14 April 2007, 23:36:08 »
Im lost MJ.....never seen that bit of pipe on an Omega....is it an air con pipe  :-/  ;)
Markjay
  • London
« Reply #12 on: 15 April 2007, 00:11:53 »
You only find them on the V6, that's why....  ;)
Markjay
  • London
« Reply #13 on: 15 April 2007, 00:14:11 »
Thanks - will give it a go (I actually have a roll of PTFE left over from a previous botched plumbing exercise). And also thanks for the help offer... much appreciated.
Taxi_Driver
« Reply #14 on: 15 April 2007, 08:26:40 »
Ahhh that'll be the reason then  ;D ;)
